Good thing it's fixed now...
Cuz this is what Kirkland Pontiac showed me when I arrived tonight to pick up my GTO...
The car has been having problems with the tires rubbing on the struts, but it looks like it should all be fixed now... but not before I had to buy 4 new tires for it... ouch. The tire above was through to the cords, and two of the others were bad enough it didn't make sense to just replace two of them.
Very happy with Kirkland Pontiac, though... they came through again for me. Been trying to get this issue addressed before my warranty expires, and they finally found the problem.
Originally Posted by WAHUSKER
Damn, that's scary Zeke! Are you running the stock wheels & tires?
I replaced them with 245/45-17 Continental ContiExtremeContact tires... same as stock size. They seem to be a little better tire, they're much quieter on the road, too.
Nice that the dealer got it fixed. John's 05 hasn't had any rub problems (yet).
You're going to hate the Conti's though. They wear FAST and howl like a screaming 5 year old in corners.
Zeke, just to be on the safe side be sure you check the inside edge of your front tires at every oil change. Better yet, get a new set of wheels with a better offset and you won't have to worry about it any more.
Did Kirkland tell you exactly what they "fixed" to make the problem go away? Some shops just dial out your camber and call it good. Others will replace your struts and mounts and then do an alignment.
BTW, my 18" wheels are begging for someone to powder coat them and take them home.
I'm just gonna have to check them about once a month.
I woulda been interested a few days ago probably, but after shelling out a few Benjamins for a new set of tires, I'm pretty tapped at the moment.
Originally Posted by DrEvyl
18" factory wheels? Why do they need to be powder coated?
So, powder coating is the most cost effective way of making them look like new again. They could be repainted instead, but that'd cost more.
