Northwest Members WA, OR, ID, MT, WY, SD, ND
What winter Mods are we all doing?
Old Oct 14, 2007 | 11:43 PM
Robert56's Avatar
Default What winter Mods are we all doing?
Just wondering what everyone else has planned.
Here's mine,
Tach
2-step
Shoulder belt added bar
Move batt to rear
Remove front sway bar
Heads/Intake L92 and new Fast
3rd stg dry (was wet and never used)
Tranny freshened up
Clutch freshened up
Drag pack if $$ are there
Drag shocks
Poly bushings
Weight removal
full 3" exhaust over axles if $$ are there
and some more or less, lol.
Will need Don's help with roll bar mods, and Ellis for the tranny, but everything else I think I can handle.
Robert
Old Oct 15, 2007 | 12:40 AM
Mikey 97Z M6's Avatar
Hmmm still lot's to do on mine:
-Finish porting the L92 head (one finished)
-Install heads
-Acquire L92 rockers/stands
-Verify PTV clearance with current pistons (flycut if nec.)
-Install longblock into chassis
-Acquire engine harness and finish wiring mods needed for LS1 conversion
-Port L76 manifold or purchase FAST LS3/L92 type manifold
-Acquire 90mm TB
-Acquire LS1 T56
-Get car running and tuned
-See how long that 10 bolt lasts.........
March 15th is the scheduled GO time!
Old Oct 15, 2007 | 01:01 AM
Poik's Avatar
A lot of custom stuff.
Old Oct 15, 2007 | 01:28 AM
krazzycowgirl's Avatar
Engine Installed MAYBE.
Old Oct 15, 2007 | 02:11 AM
1_bad_TA's Avatar
1. Ported/polished/epoxied Throttle body
2. Install the lid, bellow, thermostat, Whisper ram air I already have
3. Long tubes, ory, cutout
4. Git rid of some unwanted weight
5. Poly engine and trans mounts
6. LCA's, subframe connectors, Panhard bar
7. Drag radials
8. Spray
9. Tune
10. Trans cooler, shift kit, deeper pan
11. Free mods
12. Tune up: MSD wires, NGK TR6 or 7 plugs, fuel filter
I could keep going, but I think that will give ya an idea.
Old Oct 15, 2007 | 02:21 AM
silverbullet02's Avatar
T is for Towing not Turbo
Clutch
Change oil
Drive and enjoy
Old Oct 15, 2007 | 10:39 AM
XLR8N's Avatar
well i bought an 02 ss about a month ago that already has a few thing on it. but these are on my list.
1. im stealing roberts idea and going for a LME 408, L92 and hopefully a fast set up. but im going to go a little bigger on the cam and cr.
2. upgrade the nitrous set up to a two stage dry, prob 250-275 hit
3. clean up the engine bay ALOT.
4. shave some weight but not a whole lot.
5. HPTuners
6. and if money and time allows some madman stuff.
im going to be shooting for a full leather, show quality, 9 sec street car.
brody
Old Oct 15, 2007 | 10:42 AM
DrEvyl's Avatar
teh PuRpL3z
Meziere water pump
LS6 intake
Nitrous
That's about it... I'm getting ready to sell my house so until then I'm pretty much barred myself from doing mods on the cars.
After I sell the house, though, I might do an engine.
Old Oct 15, 2007 | 10:55 AM
HitmanLSX's Avatar
Saving money to get it running again
Old Oct 15, 2007 | 11:54 AM
93TAWicked1's Avatar
Well I think my winter mods are done after installing the Fast 90/90 setup. It is getting tuned on Friday at Tom's after that....I think its just putting it back together and cleaning it all up. I need to install my wideband gauge and adjust my torque arm but really I think I may have the winter mods done. Only thing I might do is a BMR\Koni setup to raise the car up a bit.
On a side note my mom just picked up an 03 50th aniversary C5 Vert (the marron tan interior one) LOOONG story. It only has 1700 miles on. This mean basically I have a C5 vert since she'll never drive it
Old Oct 15, 2007 | 11:58 AM
crazylane's Avatar
Well I have been wanting to do Heads and Cam, and some suspension stuff. But Me and the wife have been talking. I think I am going to try and sell the car.... I and come next year when I have these two loans payed off, and have more money in the bank, buy another Base model Z28. Without the t-tops. And go all out on it.
Lane
Old Oct 15, 2007 | 12:05 PM
99blancoSS's Avatar
procharger
Old Oct 15, 2007 | 01:55 PM
Ackattack1's Avatar
corvette: ah...weight reduction and maybe a wideband 02 to get the tune dialed in....gonna see if I can run 11s with just intake & exhaust bolt ons....only need 1/4 second!
68 truck
get the chasis assembled to have a rolling chasis
install the 5.3L and 4L60E
headers
exhaust
rebuild axle (new bearing/seals, new eaton posi)
radiator
fuel tank
plumbing (fuel, brakes)
start on some wiring (engine, battery relocation with shutoff)
then I'll probably start on body work. I have rocker panels, cab corners, floors to replace, then shave the drip rail, firewall, cowl, and fuel filler hole.
So I have plenty of work to do
Old Oct 15, 2007 | 05:57 PM
99LSS1's Avatar
Well, Ive already started. The SS is in the garage with the top end torn apart. Waiting on a few parts. Head gaskets, Head bolts. and a few other odds and ends. Got my motor mounts done, and while it's up in the air I wil probably do some intense cleaning. Hopefully I will have the money to have Ellis do the Tranny, but we will have to see on that front. Need to weld a bracket for the Harness......... I guess I have alot to do.
Old Oct 15, 2007 | 07:12 PM
Poik's Avatar
Camaro:
Wash, detail, park, repeat.
Volvo 744:
Snow water/meth pump + nozzle
Drill block for oil return (NA block)
Port 8v head, stock valves
Assemble engine
- Piston oil squirters
- 9.8:1
- 12mm lift cam, 256/256 advertised, 32º overlap
Port exhaust manifold
Bigger hybrid turbo
Cleaned/flowed Ford CFI 46lb injectors
Install Camaro T5 if my bellhousing is finished in time
Replace shocks with Bilstein HDs
Replace rear springs with wagon springs
Replace front springs with diesel springs
Should be ~300rwhp and 6k redline
Volvo 242:
- Wire with Painless universal 18 circuit kit
- Port automotive 16v head, stock valves
- Replace the marine head with that one (~11.4:1)
- Weld throttle body elbow/adapter (for LS1 throttle body)
- Finish fabricating my front coilover struts with Koni 8611 DA race dampers
- Machine control arm balljoint and tie rod spacers
- Remove live axle
- Install IRS assembly from an E30 BMW (fabricate brackets, frame reinforcement, etc.), cantilevered Koni 3012 DA dampers in back seat
- Finish getting all the tar paper off the floors
- Stitch weld as much as possible
- Cut dash out of aluminum on the waterjet at school
- Buy AutoMeter gauges
- ~190-200rwhp and 7k+ redline
- Hook up 50-75 wet shot, so 250+rwhp, 2500lbs.
- Begin maching of new engine for piston oil squirters, forged h-beam rods, 1st oversize custom CP pistons, and lots of boost!
Old Oct 15, 2007 | 08:33 PM
TwoFast4Lv's Avatar
Not much. I am closeing in on LAST years winter mod list
Blu Car
Finish installing dash
Finsh wireing
Move battery
Install Battery cut off kit
finish installing Belts
fine fit seats
Rewire Nitrous kit
Install dual bottle brackets
Aquire new 325 Drag radials
Make 325s fit
And last but not nearly least. Find another 100LBS to take out of the car!
Old Oct 15, 2007 | 10:28 PM
Robert56's Avatar
5. HPTuners
brody
Yea, I would like to go bigger cam also. The one I choose was for use with the stock LS6 heads. You know what cam specs yet you'll use?
I also forgot, am upgrading fuel system. Aux inline pump (Bosch) on it's own supply line, which I allready have, 60lb injectors. I'llhave it wired to come on when nitous is activated and should be good to north of 700/750rwhp. If the 60's run out we'll add a BAP and boost the pressure.
Looks like many are planning some big mods, next year will be fun for sure. Now if I can just keep from breaking, lol.
Robert
Old Oct 15, 2007 | 10:46 PM
Poik's Avatar
Robert what fuel pump are you running for your main line?
Old Oct 15, 2007 | 10:52 PM
Robert56's Avatar
Racetronics and Hot Wire kit, along with return and reg at the rails.
Robert
Old Oct 16, 2007 | 12:04 AM
XLR8N's Avatar
i havent picked out a cam yet, im still waiting til i get closer to actualy doing the build. i also have a few odds and ends to do, like relocate the battery, cage, harnesses things like that. but next year should be fun. hopefully the funds dont run out!!!!!!!!!!
brody
