Northwest Members WA, OR, ID, MT, WY, SD, ND
What winter Mods are we all doing?
Old Oct 16, 2007 | 12:47 AM
sidewayz28's Avatar
saving for a rear end! thats for sure
Old Oct 16, 2007 | 01:02 AM
AndreS's Avatar
helping my brother start his LT1/RX7 swap on weekends right now.
on my car- when time allows,
swap to 5-Lug wheels(more wheel options)
put in polyurethane suspension bushings
put in delrin rear-steer eliminators
new rear wheel bearings
Old Oct 16, 2007 | 12:11 PM
karthalin's Avatar
Well... ideally I could get the following done:
- Install Roll Bar
- Replace exhuast with new mandrel bent X-piping and Magna Flows
- Replace suspension with KW V3 coilovers (Really want to get this one done)
- Remove dents from front driver side fender
- Install super bad *** and cool stereo
Uhh... Wow, thats not a very big list at all. Have I finally come to my senses about this car? Am I nearing the end of modding the goat?
Old Oct 16, 2007 | 01:22 PM
XLR8N's Avatar
robert if you go with the new fast set up what are your plans for the inlet side and maf. i have a few ideas bouncing around, but for some reason every time i have an idea about something it usually ends in some sort of exstinive fab work. i think i think too much?
brody
Old Oct 16, 2007 | 06:35 PM
firehawk618's Avatar
Linelock, rear gear swap, interior change from tan to black, rewire some accessories, upgrade clutch, subframe connectors.
Old Oct 16, 2007 | 06:36 PM
Originally Posted by Poik
Camaro:
Wash, detail, park, repeat.
Volvo 744:
Snow water/meth pump + nozzle
Drill block for oil return (NA block)
Port 8v head, stock valves
Assemble engine
- Piston oil squirters
- 9.8:1
- 12mm lift cam, 256/256 advertised, 32º overlap
Port exhaust manifold
Bigger hybrid turbo
Cleaned/flowed Ford CFI 46lb injectors
Install Camaro T5 if my bellhousing is finished in time
Replace shocks with Bilstein HDs
Replace rear springs with wagon springs
Replace front springs with diesel springs
Should be ~300rwhp and 6k redline
Volvo 242:
- Wire with Painless universal 18 circuit kit
- Port automotive 16v head, stock valves
- Replace the marine head with that one (~11.4:1)
- Weld throttle body elbow/adapter (for LS1 throttle body)
- Finish fabricating my front coilover struts with Koni 8611 DA race dampers
- Machine control arm balljoint and tie rod spacers
- Remove live axle
- Install IRS assembly from an E30 BMW (fabricate brackets, frame reinforcement, etc.), cantilevered Koni 3012 DA dampers in back seat
- Finish getting all the tar paper off the floors
- Stitch weld as much as possible
- Cut dash out of aluminum on the waterjet at school
- Buy AutoMeter gauges
- ~190-200rwhp and 7k+ redline
- Hook up 50-75 wet shot, so 250+rwhp, 2500lbs.
- Begin maching of new engine for piston oil squirters, forged h-beam rods, 1st oversize custom CP pistons, and lots of boost!
Turbo bricks and be fuuuunnnn
Old Oct 16, 2007 | 07:27 PM
PONYEATER's Avatar
I am going to rip the EFI off Ellis' car and install a DOMINATOR
Old Oct 17, 2007 | 10:27 AM
Rokko's Avatar
Tech Addict
All the mods in my sig are going in this winter.
Depending on an estate issue, a 12 bolt for sure and hopefully a set of AFR's or TFS's.
Old Oct 18, 2007 | 10:27 PM
Robert56's Avatar
Originally Posted by DrEvyl
Meziere water pump
LS6 intake
Nitrous
That's about it... I'm getting ready to sell my house so until then I'm pretty much barred myself from doing mods on the cars.
After I sell the house, though, I might do an engine.
I'm looking at investing in a condo, so mod money will soon be adios.
Robert
Old Oct 18, 2007 | 11:39 PM
BoneZDriver's Avatar
I have the sticky clutch pedal problem so I'm using that as an excuse to upgrade
McLeod Twin Street Clutch (I hope TBD on this one)
McLeod master cylinder
GM 01+ Slave
Drill Mod
Pro 5.0 shifter
POW/MIA shifter **** to match the vet license plates :-)
If time and money left over will look suspension upgrades (probably sfc's)
Old Oct 19, 2007 | 01:50 AM
TwoFast4Lv's Avatar
There you go trying to slow my car down again!
Old Oct 19, 2007 | 07:33 AM
  #32
PONYEATER's Avatar
Not a chance.... you know that EFI only make more power in BOOSTED applications.
Old Oct 19, 2007 | 10:27 AM
  #33
Ryan K's Avatar
Pathological Modifier
Cage, shute, suspension, and weight loss....
Old Oct 19, 2007 | 10:33 AM
  #34
Ackattack1's Avatar
Originally Posted by Ryan K
shute
Old Oct 19, 2007 | 01:13 PM
  #35
jester1614's Avatar
I am looking to lower my car.
then relearn how to park it without scraping the crap out of the front end
then paint it viper steel gray.
Old Oct 20, 2007 | 10:13 AM
  #36
rotwiler's Avatar
Viper steel gray - very nice choice.
All I am going to do is a good detail and buffing... then in the spring getting the SS hood painted and put on.. Finally have a true SS hood, so for sure it is going on. If I can figure out a way to tuck up the headers some more I may lower it.
Old Oct 20, 2007 | 08:45 PM
  #37
Z ANGEL's Avatar
I want a new car...but I need to win the lotto first..
Old Oct 20, 2007 | 09:23 PM
  #38
Layn_Low_247's Avatar
19x11 and 20x11
IForged Aeros Black w/ Chrome Lips or Silver w/ black inlay and Chrome lips. Either way, just some new shoes.
  #39
Robert56's Avatar
brody
Not totally sure yet. I do know that Lingenfelter has a 101mm TB and MAF, IIRC. Also, FAST may be coming to the rescue. We'll figure it as we go, I guess. The fly by wire guys have less options for big stuff. That one aluminum intake manifold company (can't rememeber name) has some big mm items coming also, but for cable guys only at first anyway. Cutting edge is allways fun, but if ya want to go fast we must stay on top of options.
Robert
Old Oct 20, 2007 | 10:21 PM
  #40
WAHUSKER's Avatar
Did you enter the Bumblebee Contest yet? Somebody's got to win it......
I'm building a new car with some upgrades. My "plan" is a Vic Jr intake, 1 7/8 headers, bigger fuel pump, lines & rails, FMIC?, dbl adj shocks, AC & ABS delete, + some roll bar & SFC improvements. We'll see how far I get.
