What winter Mods are we all doing?
Seems I've finally decided on my mod list for the new setup, so I thought I'd post....
Vic Jr intake w/90* elbow & fuel rails
Twin Walbros w/10? AN lines
FMIC w/ploished alum tubing
UMI tube K-memmber & A-arms
Dbl adj HAL shocks w/325# front springs
Oil cooler
3000 cfm Spal radiator fan
AC & ABS delete
Plus some other minor stuff.....
I can't afford to keep up with "the big boys" but I'm hoping I'll be able to stay in the top 10 with this setup. But as crazy as some people are getting around here, you just never know.
Oil cooler
AC & ABS delete
I hear you Mark. Keeping up with Ryan and Robert are an impossible task.
I have some set plans now
1. Install MADMAN suspenion
2. Finish Wieght reduction (not as much as many
3. Get the new electronics installed
4. Get car painted
5. Finish 325DR install
6. new duel bottle mount setup
7. try to get the car back on the ground
)3. Get the new electronics installed
4. Get car painted
hey mark, i dont know if you have seen this or not but heres a vic jr with elbow.
https://ls1tech.com/forums/lsx-parts-sale/804878-vic-jr-intake-w-nitro-dave-s-elbow-50lb-injectors.html
Well, since I am keeping the car, My mods list is going to look like this.
Just ordered, Performbuilt level 2 Tranny.
Going to get,
UMI Rear suspension Package
3.73's
Driveshaft loop.
Will be getting this stuff in December, hopefully, hint hint XL8RN. lol.
TEA 2.5 5.3 Heads
F11 Cam, but changing that to something else
Yella Terra Rockers
Pushrods
Lifters
Another LS6 intake
Harris speed works N20 system
Oil pump
Timing Chain
And maybe but not to sure yet
15x10 and 15x3.5 prostars
Roll cage.
Hopefully with all this I can break into the 11's hopefully low 11's
Going to get,
3.73's
Driveshaft loop.
TEA 2.5 5.3 Heads
Yella Terra Rockers
Pushrods
Lifters
Another LS6 intake
Oil pump
Timing Chain
Roll cage.
I'll update my progress on my list
68 truck:
check
get the chasis assembled to have a rolling chasis
install the 5.3L and 4L60E
check
headers
exhaust
check
rebuild axle (new bearing/seals, new eaton posi)
radiator
fuel tank
plumbing (fuel, brakes)
start on some wiring (engine, battery relocation with shutoff)
then I'll probably start on body work. I have rocker panels, cab corners, floors to replace, then shave the drip rail, firewall, cowl, and fuel filler hole.
So I have plenty of work to do
check
get the chasis assembled to have a rolling chasisinstall the 5.3L and 4L60E
check
headersexhaust
check
rebuild axle (new bearing/seals, new eaton posi)radiator
fuel tank
gonna install 60lb injectors, fuel booster pump -=- plug and play racetronix
start saving for the rear end..
i would like to get a 2-step but only if money is there.
putting myself through school this winter so money will be tighter.
