Reground camshafts...
The bottom line.....
"You pays your money and you takes your chances."
BTW- Love the pic in your sig...haha
IMO, stay away...
just search around you can find good used cams on here for under $200. got my lingenfelter 228/232 114 cam on here for $150 and made 390rwhp sae cam only through a 4k stall auto
The camshaft lobes have to fit through the camshaft bearing holes so the camshafts are usually set up with lobes fairly close to the bearing sizes (but obviously smaller).
That is why even a 2002 LS6 camshaft has a smaller base circle than a 2001 LS6 camshaft.
A Comp Cams, Lunati, LPE, or any other camshaft with higher lift than a factory LS6 camshaft is going to have a smaller base circle or you wouldn't be able to get the lobes through the bearing holes.
The Gen III/IV engines have fairly large base circle camshafts compared to the earlier Gen I and II camshafts. I have seen some pretty small diameter regrinds on Gen I and II SBC engines but those were mostly for drag racing applications where durability wasn't as big a concern and where you are testing out dozens of camshaft designs during engine development (and you are planning on changing pushrods lengths etc. anyway).
A bigger concern with regrinding the camshafts is the durability of the camshaft. The heat treating process only impacts the outer surface of the camshaft material. When you regrind the camshaft you remove this harder outer layer and expose the softer material below. I would ask what they do to re-heat treat the camshaft. The factory GM Gen III and IV camshaft material is designed to be induction hardened but you can't do that to the finished camshaft without distorting the camshaft. Also, very few aftermarket companies have the equipment to do induction hardening of camshafts.
If this is just for testing on the dyno, regrinding a couple camshafts can be a cost effective way to have different things to try out (and a way to re-use something that turns out not to work well for your combination).
I have seen this first hand on a 'Cheap ***' who just had to save $100 bucks and it cost him a motor.
You live and you learn. Don's Statement seems to hold water
exactly, my reground cam when i pulled it all the lobes were all messed up.
also off topic, Just wanted to say to Jason, You guy make/engineer great products, i resently put in one of your guys 228/232 588/595 114 spec'd cams and it run almost like stock and makes more power than a TSP MS4..
390whp SAE cam only through and unlocked TCI 4000 stall
