Are Stage 2.5/3.0 LS6 heads a good choice on a 402 or 416 shortblock
I currently own the ported LS6 heads and can have them upgraded to stage 3 (larger valves) for $500. Right now (this week
I am leaning towards the 416 shortblock. Depending on which vendor you talk to, they provide conflicting answers on if the ported LS6 heads will perform well. At a cost of only $500 to upgrade to stage 3, I would rather go that route than spending $3k on a set of heads. However, if there is a substantial performance gain, I would consider upgrading the heads.
Thoughts?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thoughts?
I'm curious as well. Looking at a LQ9 408 and currently have brand new S2 heads on my 347 with a dead cylinder. Just to keep costs down I plan to reuse them on the 408, but curious how much HP I might be losing with them.
Aaron, I recently tuned a 402 with LPE LS6 heads using a 238/242 cam. That C5 made 460+ to the wheels. So yes they would work, especially with the right cam and the extra stage 3 port work. A better head maybe some hogged out Edelbrock or TFS 245cc heads. Or you can go up from there.
Yep as Tom said the ls6 stage 3 isnt a bad head.
I'll cut you a deal on the Edelbrock 245cc , it takes your stock rockers, no valve cover spacers needed either. THis is where the TFS cost more.. rockers and spacers or taller covers
You can sell your heads to make up some of the cost. The price on WCCH site is $2440, I have been autorized to cut a sweet deal on them. Get your shortblock from me and I sweeten it even more.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Do the Edelbrock heads and the FAST intake match up correctly? I thought there were a few posts stating the intake runners did not align. I already have a ported 90mm FAST and ported LS2 throttle body so I want to stick with a head that matches the intake.
Do you offer AFR or TrickFlow heads?
The only thing that is stopping me on buying a new longblock is that I cannot decide on which heads and cam to use.
That mismatch was another company's cnc program that I can't mention for fear of reprisal. These are produced by WCCH. Edelbrock makes the blank to be cnc'ed. SO that mismatch was the result of someone not doing their homework when they cnc'ed the head. I do offer trickflows as well but your looking at an investment in rockers and iirc valve cover spacers or taller valve covers and an AFR 225 is more money. This is why I really like this 245 Edel, perfect in betweener TFS AFR 225 cost more L92's less but the intake restriction. We figured 525 -545 rwhp with a proper cam with a 408. But they're so new there arent to many numbers out there yet. Man I'd sell my engine in a heartbeat just to buy a 408 and prove the heads are worth it. I'm pushing them because I know Richard does good work . The flow numbers dont back up at 600 like most heads do they keep flowing to 700. Small increments but its not backing up, it has to make some power. 337 and 240 at .700 arent bad flow numbers at all. The L92 and Ls7 stuff is of course better but it's a different animal.
I talk to Richard and see if I can get any pics from him with the bottom half of a 90 on there. Not sure its possible but I know the concern. I had a set of those port mistmatched to a 90 heads. I wouldnt do that to someone.
Of course I've got a killer set of All Pros for $2600 but the rockers will cost ya $1680
Hell bone stock ls6 heads on my 408 was good for 430/450 with a very small cam, lol (big cams are not always the route to take). The Edelbrock heads sound like a good deal for sure, though I would prob need to jump upto the super Vic and dump the Jr?
Robert
Robert
Robert
Robert
Yea I will have a scoop regardless of which intake I use. Still will need a 90° elbow, like the Edelbrock version. though I have been looking at combing the MAF and TB to mount right on top of the carb flange. I have seen it done and they just run a standard type carb air cleaner. however, that's for later and am going elbow at this time. then one I have is a piece of junk and will prob have elbow.com build me one to my specs. Still will be going with some cheap heads sometime in the future. I should call Vic and see if he will cut me a deal on heads/intake/elbow, as he always has in the past (senior mechanic/shipwright on his last two mega yachts).
Robert
Robert
