color sand and buff question
I guess I'm not completely sure what the aspects and specifics are of the situation...
i just use a circular buffer, and start with a rubbing compound, then a fine cut polish, and follow it up with a swirl cutter. then finish it with a sealer. i use nothing but the buffing pads from tropi-care.
might not be the best way, but it works good for me.
that said you need to take many many steps..
I normally 4 step my black cars..
wool pad with a compound
poorboys SSR3,high temp extreme leveler. or the like..(if your wet sanding 2500/3000 you can skip if you want)
lt cutting foam pad light compound
Poorboys ssr2.5,optium hyper coumpound,menzerna SIP,meg 105
polishing foam polish
Poorboys ssr 2,optium polish,meg 105
Finishing foam polish
poorboys ssr1,opt polish , meg 205,menzerna final polish II
Now the final polish is where your going to get your depth and wettness.
before
after
http://www.autogeek.net/
or detailcity.org
