Shaved Bird emblem on plate cover?
I don't think you guys understand this: if I shave the bird down there will be a bird shaped hole! I need to attach something to the back (somehow) and some sort of flexible filler material. It's the same material as the bumper.
I can't use Bondo because of the panel flex...
if i were you i would lay down some fiberglass sheets and resin on the back behind the logo and push it in kind the inset shapes of the bird on the back, then get your dremel and shave them off on the outside leaving the fiber glassed back showing through the holes where the bird used to be, then get a body filler and fill it in, sand, paint, done!
No... Not only am I terrible at painting, but I need to run a front plate with all the driving I do (10k miles since February). Really don't want to be bothered with getting pulled over for a BS reason... I'd keep the plate cover in the car and only put it on for photoshoots and meets.
Its pretty easy......go ahead and use a grinder or dremel whatever you preffer and cut the bird out. Then kind of like mentioned earlier take some fiberglass matt/resin and lay it down on the inside of the panel. Put a few layers down making sure you go past the bird a good bit!! Make sure you sand it down and clean it first so it has a good addhearsion. After that sets up take some 180 or 220 and sand the fiberglass from the outside where you see it through the bird outline. This is so the fiberglass filler has a good bite. Then use some short strand fiberglass filler and fill the bird in smoothing it out two in or so past the bird. Sand that down to where you think its as good as you can get it then spray it with some good high build primer. Sand it down smooth and spray another coat then wetsand it to 1200 and paint. Sounds like alot but its actually pretty easy!! Especially with a small piece like that!! Good luck and hope I helped some!!
Heres a great site you can read up on this is covered all the time there!!
http://www.fiberglassforums.com/showthread.php?t=199
