Epoxy vs. Urethane Primers...
Link to EPOXY: http://www.eastwood.com/paints/prime...allon-1-1.html
Link to Urethane: http://www.eastwood.com/paints/prime...allon-4-1.html
the epoxy sealer is just that a epoxy based sealer all sealers are non sanable like ppgs dp line that is a corrosion resistant sealer, it is used on bare metal or bondo work before primer, but now again im going to use ppg here the ncp 271 primer is a urathene based primer filler that is water proof, corrosion resistant primer, and that line also has a epoxy sealer which is not corrosion resistant becasue the primer is urathene based and rust resistant
some product lines use a corrossion epoxy based sealer and the primer is high build uathene based primer, example again spies hecker uses a epoxy based sealer primer is high film build, nothing is corrossion resistant so you have to use a etch prime before sealer can be applied, again etch prime is a non sandable primer has one job that is to protect against rust
am i making sense here??? epoxy based sealers are non sandable, urathene based primers are high film build and sandable, some are rust resistant some are not
i never used eastwood paint line always used a product line like ppg, spies hecker, and so on i would stick with a product line that will last and doo the job correctly
if your buick is bare metal, i would use ppg`s dp sealer line, then use the ncp 271 primer some of the best stuff in the buisness right there
until perfect
You dont need to go to eastwood for your supplies, just try and find a local body shop supply store near you. Eastwood is expensive when is comes to certain things.
but if you use ppg`s ncp sealers which is a non sandable sealer something has to be put over it right away, if you use ppgs dp sealers or any sealer for the matter it has to be scuffed down with a red scuff pad, re apply the sealer then apply your primer
or you can just use the ncp 271 and then there is no need for a sealer before primer
I am waiting on my new soda blaster to get in so I can quickly remove the paint from the body...at that point I will decide exactly what timeline I have. I will probably seal it and then start body work. Good thing is the vehicle is in a garage which is very dry. Rust should not be a problem- I will remove any flash rush if it shows up but should not be a problem like I said.
Should be fun...
