98-02 Ground effects on 93-97 Camaro.
Well guys here it is my 1996 Camaro RS, I know its not a LT1 or LS1 but it gets the job done just fine. First thing is first let me share alittle bit about the history of the car.
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0064.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0037.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0040.jpg)
When I first bought it this was your plain jane Hard Top basic camaro and I changed all of that with a one of a kind T-Top conversion. It had a ton of problems but I've managed to fix through all of them.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0035.jpg)
I originally wanted the 93-97 Ground effects package for the car but after searching around for them I found out quickly they were outragous in price. Also I didn't like the front lip especially for out here in Colorado Springs where the road conditions aren't to good. We have a lot of pot holes and many areas around town with construction so the front lip was not an option but I still wanted to make the car look "Complete" rather than delete it.
A guy out in Denver had a par of ground effects for sale at $300 which came off his 98 Z28. So I traveled up there on spring break to go get em and brought them back with me. I must say they where in great shape other than the two front canard peices which will need a complete resand and surface.
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0073-1.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0074.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0076.jpg)
Sorry for the qualitly of the pics I do not have a high grade camera and this is all I can do at the moment.
The Rear lip from the LS1 will bolt right into the LT1 bumper and so will the side skirts without a problem at all. We had to order some body fastners and 3m tape but other than that everything works just fine.
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0081.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0082.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0080.jpg)
The front canards will requre alittle science
I've test fitted them a few times and even turn them upside down
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0072.jpg)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
In order for this to work on your LT1 front bumper you will need A lot of Patience and a heat gun. This will only work with urathane ground effects, I highly doubt it will be this easy with a fiberglass kit to do.
You'll have to make a minor cut on the inside of the aero peices somewhere on the middle. Once you mount it into the wheel well simply take your heat gun and mold it to the contour of the bumper. Repeat the same process on the otherside and it should look like this.
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0087.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0088.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0085.jpg)
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/DCFC0084.jpg)
It gave my car the facelift it needed all for under $300 on my $500 dollar budget. I went out and bought me a Freedom Wing off Amazon.com for $127 including shipping! so I'm at $427!. Not only is this is unique one off body kit but its getting me closer to my goal of building a ZL1 Replica
I really liked the car before they did the 98 front end conversion on it.
Next I need to do paint work on it. Sadly every shop locally wants at least 4 grand for paint!.![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
I've thought about doing the rustoleum paint job to it but I'm highly inexperienced with body and paint work. I don't know how to do it.
I was looking to painting it Buick Grand National black or if the money permits TVR Speed 12 blue.
Right now I'm sporting a 2 ton silver
It actually looks okay kind of reminds me of the 1980's Irocs but thats not what I'm shooting for.
But it certainly stands out from the typical RS ground effects you'd see on a 93-97. Not to mention I feel more confident driving around on Colorado Springs roads with all these Potholes and F'ed up roads we have here without the fear of losing my whole front end.
It does very wheel even in light snow conditions, hell I've even driven it on a country dirt road and didn't have an issue. No scrapping, No scratches. It gives me the look I want.
![](http://i304.photobucket.com/albums/nn189/vf1skullangel/camarozl1_3.jpg)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
It works a hell of a lot better than the stock RS front lip. That I can tell you straight up. Especially when there's many pot holes locally, I couldn't have picked a better application than my design.
Ill see when it gets back from paint what I'm going to do b/c I like the salad shooters, I wouldn't mind painting them black or copper. All I have found for this car locally so far has been Corvette rims and I do not want to go that route. I do want to increase the volume around the wheel wells like your friends car and wheel spacers might be a possiblitly for my car.
mmm may b where u live is a bit cold area belive me where i live a camaro WONT survive if it has a front LT1 groud effects i had a V6 before with grounds i had to direct wiree the fans but then i had to remove it coz it over heated many times and now its fine lol anyway gd luck with ur car
show us how shes gna look in the end
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
show us how shes gna look in the end ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
With the summer coming up we often get over 90 degrees in July on avarage so we will see if it will heatup or not.
