Got a little spot of rust....
Old 06-24-2010, 01:22 AM
arioch's Avatar
Default Got a little spot of rust....
on the inside of the engine bay. what should/can i do about it?
Old 06-28-2010, 04:12 PM
arioch's Avatar
Anyone? any suggestions at all?
Old 06-28-2010, 06:25 PM
SparkyJJO's Avatar
Where at in there?
If you're like me and the appearance of the bay isn't a big concern, I'd sand it down, clean it, then prime it. Then maybe spray some "matching" paint on it, then clear. It may not match perfectly but it would take care of the rust.
Old 06-29-2010, 08:16 PM
arioch's Avatar
its right on the metal right behind the headlight, i believe its the radiator support
Old 06-29-2010, 08:37 PM
USArmyZ28's Avatar
Use one of the rust removers available at auto stores, sand it, prime it, paint. At a minimum sand it to remove the rust before it eats away more then what it already has.
Old 06-30-2010, 11:10 PM
camarox302's Avatar
Simple quick fix and will be fine. sand it till the metal is clean and use some rust preventative primer. If you want to go nuts with it get a pint of por-15 or something similar and top coat it.
Old 07-01-2010, 05:46 AM
9WhiteCamaro9's Avatar
^ what he said
Old 07-07-2010, 04:15 PM
Stew215's Avatar
simple fix just do as others have said.
