Tips on painting LS6 Intake Manifold?
Old May 6, 2011 | 10:39 AM
Gottahavels1's Avatar
Default Tips on painting LS6 Intake Manifold?
I'm about to purchase a factory ls6 intake manifold for my 99 T/A and I was thinking of painting it a Gunmetal/silver color. Do you guys have any tips for doing such a thing? My dad will help me and he's knowledgeable but I'd like to get your opinions. I figured there might be different things I'd have to do since it's made of thermoplastic and I'd probably have to buy some heat resistant paint. Let me know what you think! Thanks in advance.
Old May 8, 2011 | 12:20 PM
mhorn0817's Avatar
nothing out of the ordinary really, i painted my buddies intake on his 05 gto years ago and he hasnt had a problem at all......make sure its very well degreased and cleaned, sand it with a finer sanpaper since its plastic, no lower then 800 grey, and you can use a grey scuff pad as well to go over it...pick a paint company you want to use (duplicolor,etc) and follow their reccomendations.... you can put down an adhesion prometer, plus a hightemp paint, and even a clearcoat, thats what i did, all from duplicolor and it turned out great and have had no problems.
Old May 8, 2011 | 02:31 PM
-Q-'s Avatar
-Q-
I painted mine gunmetal gray not long ago...here's my thread on how I did it...
https://ls1tech.com/forums/appearanc...-thoughts.html
Old May 8, 2011 | 02:59 PM
bene's Avatar
Trunion King
Use the following:
Plastic promoter
Primer- high filler if you want to get rid of the casting mark on top of the intake.
Paint/clear.
Wait 15 mins min for every coat, use a very light coat on the first one and progress to heavier coat on each coat.
Good prep is the key.
Here is what mine looks like after it was all said and done.
Old Sep 2, 2011 | 03:44 PM
YellowTA1's Avatar
did you use the high temp paint? going to do mine this weekend. that looks really good
Old Sep 2, 2011 | 03:46 PM
bene's Avatar
Trunion King
No, just normal rattle can stuff from Autozone.
Old Sep 3, 2011 | 11:13 PM
BlackBirdDaddy's Avatar
With my color scheme, I used Duplicolor engine paint with their clear. Same process as mentioned above. Take your time prepping because it is the key to an ok or a "real fine" job!
Old Sep 5, 2011 | 10:15 AM
DDrumR's Avatar
Dude your intake turned out awesome! Color look great but it would have looked good painting it SOM
Old Sep 5, 2011 | 12:25 PM
99french's Avatar
I also smoothed the intake casting marks by sanding the runners down first an that kept me from having to build up a ton of primer to have a nice smooth finish.
Old Sep 5, 2011 | 10:19 PM
kwiksilverz28's Avatar
Spend the time and do it right...
Old Sep 5, 2011 | 11:29 PM
Whistler's Avatar
Sawzall and Welder Mod
A tip for prepping the intake is to use a red scotchbrite twisted up into a little cone to sand the hard to get into crevices. Blow it out with compressed air before and after prepping it.
Old Sep 10, 2011 | 10:35 AM
Simon Pheonixxx's Avatar
Cool
.......That ......Is.........Gorgeous!
Old Sep 13, 2011 | 09:01 PM
That is gorgeous!
Old Sep 14, 2011 | 10:20 AM
1BlackLS1's Avatar
Really wanting to do mine now...about how long did it take yall to complete..a day?
Old Sep 14, 2011 | 02:01 PM
Blu99T/A's Avatar
Here is a few that I have done.
Also did the Valve Covers on this one.
After you do your intake, maybe you will consider doing your lid? Mine started out as an "SLP" lid.
Old Feb 4, 2012 | 07:45 PM
sokr915's Avatar
Originally Posted by bene
Use the following:
Plastic promoter
Paint/clear.
Have any pictures of this installed? I just bought one and am trying to decide what color to paint it.
Old Feb 8, 2012 | 03:38 PM
-Q-'s Avatar
-Q-
Just did another one this week...
Old Feb 8, 2012 | 04:10 PM
meine96ws6's Avatar
ahh, makes me want to rip mine out and do it..
Old Feb 8, 2012 | 07:32 PM
98camarols1's Avatar
here how i did mine..
clean it thoroughly
scuff it with gray scotch bright,or if you want to prime it which i did due to the little plastic repair i had to do.if you prime it 320 it.put LIGHT coat of plastic adhesion promoter and 2-3 coats of primer surfacer(first coat should be light)
then sand the primer with 320 followed by 600.(this is optional: you can put 1 light coat of primer sealer then you will be ready for base coat.)
clean it with plastic cleaner,then tack rag it.apply 2-3 coats(first should be light coat or it will fish eye)after you put first coat let it flash and take 1500 to knock down any nibs or imperfections.then tack it again.then apply other coats.
now your ready to clear it.2-3 coats.make sure there is no dry spray.put nice wet coats.let it flash between each coat unleast 15-20 mins.now just let it dry and congratulate your self.if you don't want to prime it then just put scuff it with gray scotch bright or 400-600 sand paper.then put adhesive promoter and base coat and clear coat.good luck!here some pics of mine
[IMG][/IMG]
Old Feb 8, 2012 | 10:40 PM
HOTROD98Z's Avatar
Here's mine
