Protection used when painting with urethane paints
I've heard several stories of people using 1/2 mask organic vapor masks when spraying isocyante-containing urethane paints. From everything I've read, these are insufficient for protecting people from the harms of urethane paints, not to mention that the isocyanates can be absorbed through skin and can cause eye damage and are toxic.
So, my question is, what are you using for such protection when spraying outdoors, in your garage and/or spray booth?
Thanks
Thanks
Decided to do a bit of research on this, and it appears that organic vapor filters would work at protecting from isocyanates as long as they were replaced very often, as you could not predict, nor detect, when they fail. Since the isocyanates could affect eyes, I would opt for a full mask with a paint suit and hood.
The filter technically lasts for 24 hours. While this may have some truth, I'm sure it is mostly marketing to sell more filters. I've used filters that are months old, no smells. Store the whole mask in zip top bag to help it last longer. Half masks are just fine for weekend warriors, but full $1000 systems are best. $30 at Lowes for 3M half mask will be fine.
The high volume exhaust system(fans) should be pulling most of the fumes out of the area. If you eyes are burning, you aren't moving enough bad air out.
Painted my daughter's RAV4 bumpers this past weekend using lacquer. First adhesion promoter, primer, base color then clear coat. Gotta do a better job of moving fumes around, even though I did this at door of my garage. Learned that I need to better dial in the gun and get fans to move fumes away. The end result was a little too much orange peel, but I can sand and buff that. Gonna give it a couple of weeks to cure.
Did occasionally get some odor, but I've got a goatee and that may have caused leaks. When I used one hand to push the mask more firmly onto my face while spraying with the other hand, it worked better, so I probably have to make the mask tighter.
Lacquer isn't so bad, that's why anyone can buy lacquer rattle cans of paint. I've been fine with no mask with good ventilation.
However products with solvents such as tert -butyl- acetate can f you up. Chemicals can absorb through your skin also. Sprayed conversion varnish at work years ago for the first time not knowing what was in it. Next day lungs were fine , but felt like I just got kicked in the nuts. Not good.
if you are like me a don't want to shave for a mask, you can use vasoline and just put a bit around the seal, it will help create a seal. but yeah for once just get a good cheap mask and be done
