Custom Hood Mods
I can't delete the plate hole because TX requires a front plate. I got around that by mounting a modified plate to the air dam, but you never know if a cop decides it is not enough.
http://www.gimp.org/
GIMP may be a good program, but why use a clone when you can get the industry standard for free?
I did a couple of pics just to get an idea. I can't have it sticking too high because it blocks your view so I thought about sticking the top half of it out of the hood. I could make a depression in front of it so you see the whole thing from the front, but since they are so expensive, I doubt I'll ever get one. Here are a few pics for your amusement. I know you've never seen anything like this before.
Or to see that coming up behind you. I think I could do it once I get an extra hood to mess with. I'm glad somebody liked my idea, most of the time people can't deal with serious body mods.
I'm in the SE area, BTW.
I'll be gettin an extra hood soon to play around with.
I'd go for that in a heartbeat! Throw a hood-tach with say, a vacuum pressure gauge and you're good to go.
I just imagine seeing the back side of it shaking while going down the road. Should be badass from the drivers seat. I wouldn't run a tach on the hood, but maybe a shift light would look OK. I'd like to make the whole front of it visable, but may have to have just the top half sticking out. I'm going to have to move the MAF and stock filter box if I want to make the whole scoop more than 12" long. I'm sure it would look a bit stubby if it were 10" wide and only 12" long. If I move the air filter to the smog pump area like the LT1 cars, I could lengthen it more towards the front.
