CETA Bumper: A How To
Old Jan 29, 2007 | 08:16 PM
  #61
Sgt. Spuds's Avatar
Shirley Temple Drinker
BTW when I did mine I used regular PPG paint, no flex additive.
Old Feb 28, 2007 | 03:12 PM
  #62
camaronut502's Avatar
How many cans are needed to do this?
--Matt
Old Mar 2, 2007 | 02:18 PM
  #63
Ima get mines's Avatar
Nice write up. I'd like to try this when I get rims.
Old Mar 3, 2007 | 09:41 AM
  #64
THE_SUPRA's Avatar
that looks great certainly worth the time
Old Mar 5, 2007 | 01:09 PM
  #65
jtcWS6's Avatar
I am going to be doing this durring spring break I will post picks as soon as I am done!
-Justin
Old Mar 27, 2007 | 10:34 AM
  #66
EndlessSummer85's Avatar
This write up is def sticky worthy... Thanks for the write up will be doing it asap.
Old Mar 27, 2007 | 01:47 PM
  #67
carado1984's Avatar
Im thinking of doing silver.. do you think it would look good? also would do the calipers silver.. not sure though.. just want something different than a plain old black ws6.. but with chrome wheels i think i would look ok
Old Apr 2, 2007 | 06:04 PM
  #68
1meantransam's Avatar
how much did this roughly cost to do that whole job, and how much time?
Old Apr 4, 2007 | 12:21 PM
  #69
Andrews_Motorsports's Avatar
Nice write up! I'll be doing this to my car shortly!
Old Apr 18, 2007 | 06:39 PM
  #70
staringback05's Avatar
i believe its a good write up also....
i kinda symplified things though....
i just wet sanded mine, cleaned it up with a alcohol rub down, and used a matte black paint....several coats.....
i taped off the bumper and then just cut it away with a blade as to not pull any paint....
Old May 1, 2007 | 10:36 PM
  #71
twpayne75's Avatar
Starting mine at 8:00 a.m.
God I hope I don't screw this up.
Old May 2, 2007 | 08:17 PM
  #72
twpayne75's Avatar
Damn! It turned out perfect. Best mod (definately cheapest ) yet. Thanks for the write up. Made it much easier.
Old May 15, 2007 | 12:08 AM
  #73
ryanisfast's Avatar
it cost me $10. The paint was 5.99 and the sandpaper was like 2.99 at schucks. Here's mine. It took me about 1.5 hours
Attached Thumbnails CETA Bumper: A How To-photo_0065-1.jpg
Old May 20, 2007 | 08:05 AM
  #74
Raleigh TA's Avatar
Excellent write-up! I am painting a hood scoop...for about the 5th time, and the steps here will help. Before I was wet sanding between each primer and color coat. This time I sanded between the primers, but am laying on several color coats before wet sanding. Still haven't decided on using the clear coat. Plan to polish the color coat if I don't clear coat. I am worried about the clear coat lasting with the engine heat on a scoop.
Old May 20, 2007 | 08:49 AM
  #75
Rowdy94's Avatar
I just got mine done a couple days ago. I spent probably 6 hours on the whole project including running to get supplies. Most of that time was in prep work, as well as removing and reinstalling my bumper. My dusty parking lot was a bad place to do this, so it had to come off.
Cost was about $20. I used 400 and 1000 grit, Duplicolor adhesion promoter, and Duplicolor bumper coating.
Old May 20, 2007 | 09:21 AM
  #76
My94TransAm's Avatar
Dang I want to do this now. I am not sure what gloss to paint it. But I need the whole car repainted.
Old Jun 25, 2007 | 01:32 PM
  #77
Caveman1990's Avatar
I wonder how a CETA would look on a Dark Green T/A....
Old Jun 26, 2007 | 04:32 AM
  #78
you try a search for it....ive seen them before...
Old Jun 28, 2007 | 11:02 PM
  #79
I still haven't found one....
Old Jul 15, 2007 | 07:53 PM
  #80
FLA02TA's Avatar
I did it yesterday and did a re-pass today as I suck at painting..
I had to take the bumper off, because one exhaust tip wouldn't budge. It was easier than I thought it would be. I also got to get the condensation out of the passenger tail light in the process :)
I also had a chance to bend the passenger tail pipe down as it used to ride on the plastic. The shop that did my headers apparently didn't seem to want to put much effort into it (I had a piece of trim over the tip to keep it from burning the plastic and it looked tacky). I put a piece of rebar in the pipe and hung 60 pounds of weight on it all day.
While it was drying, I took the time to sand all my plastic trim around the windshield that had water spots melded into it which would never come off with washing/waxing/back to black. The grit used in this guide worked great, and I eventually ended up with a dryer sheet as my final polish grit (a little trick I learned refinishing canopies for model airplanes). They look like new. The 2k grit also took the water spots off the center piece between the t-tops.
It came out good for how bad I am at painting. I have a new respect for painting and the patience it requires.
The first pass I tried to do flat black with a gloss coat to finish. The flat black automotive paint I bought was powder-ish. I don't understand why it came out that way. Maybe a paint guru can explain. I ended up resanding the 2k grit and went to gloss black which worked.
I missed a spot on the top left corner by error of a bad masking job. I hope I can take a small paint brush and touch it up later without messing it up.
How long should I wait before washing/waxing that part now?
Attached Thumbnails CETA Bumper: A How To-ceta1.jpg
