Primer for caliper paint?
Old Jan 2, 2007 | 12:27 PM
kaos_'s Avatar
Default Primer for caliper paint?
Just wondering, is there a solution I can soak my calipers in to completely rid them of all the dirt and grime stuck on them, instead of cleaning them by hand? Also, is there a primer I can apply to them before using caliper paint so the paint sticks even better? Just wondering what I can do myself to get the most durable paint application at home. Thanks!
Old Jan 2, 2007 | 12:45 PM
mcmillion's Avatar
I got the duplicolor caliper kit, I just cleaned them real good and hand-painted them. They came out great. I didn't have to tape off sections of my car, like I would if I sparayed them.
Old Jan 2, 2007 | 01:52 PM
bene's Avatar
Trunion King
brake cleaner/engine cleaner/wire brush.
Old Jan 2, 2007 | 05:19 PM
01 Red WS6's Avatar
can you see the brush lines or is it nice and smooth?
Old Jan 2, 2007 | 05:50 PM
kaos_'s Avatar
the brush that comes with the duplicolor kit is a joke. the bristles are very hard and break off, making it difficult for a smooth finish, other than that the kit is awesome. just wanted another brush. i plan on spray painting this time around for a nice even finish.
Old Jan 2, 2007 | 07:04 PM
thecarolinakid~98ss's Avatar
Are you guys taking your calipers off to do this? or leaving them in place?
Old Jan 2, 2007 | 07:42 PM
sdm1234's Avatar
the calipers are originally, naturally textured, so you wouldn't see any brush marks anyway.
Old Jan 2, 2007 | 07:52 PM
01 Red WS6's Avatar
I've sanded my calipers smooth so they would look better when I painted them.
Old Jan 2, 2007 | 10:09 PM
kaos_'s Avatar
there is a bolt behind the caliper that if you take off will allow the caliper to come off a bit and hang loose to the side. then you're able to either paint it by hand, covering more area since it's exposed, or you have room to trash bag everything off and spray paint it. you really don't need to take them off, unless you're **** about it like me.
Old Jan 3, 2007 | 12:08 AM
houseylou's Avatar
i just used a simple brillo pad with some heavy duty cleaning solvent (marine cleaner). it left the surface nice and rough and the paint stuck very well. i didn't use a primer, although some ppl do.
Old Jan 3, 2007 | 12:09 AM
kaos_'s Avatar
but if i were to use a primer does duplicolor make one? what do i look for that will work for that type of automotive application?
Old Jan 3, 2007 | 01:11 PM
slt200mph's Avatar
No primer is needed .. I just use Emergency Red that you buy at the Home Depot..I used brake clean on them and then washed them with soap and water..left the calipers connected to the brake lines and put plastic bags over the rotors and spray painted them ... I redo them every spring and they always look good..there is a good color to match the factory caliper brackets and center of the rotors..it is called stainless steel also available at home depot..painting your brakes is no big deal...some of the stories I have seem on here and how much unnessary work that people do is beyond me..all 4 brakes take at the most a couple of hours and look good for a year or more I squirt them with windex and wipe them off with a paper towel when I wash the car to keep them looking good ..
Old Jan 3, 2007 | 07:57 PM
angrychicken's Avatar
+1 for sanding them. they come out cherry!
Old Jan 3, 2007 | 08:01 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I used Dupli-Color also--no primer needed..just get rid of grease and dirt......
Old Jan 3, 2007 | 10:21 PM
67RSCamaroVette's Avatar
i polished my rear brakes,
and sanded my front and painted them with BC/CC. looks sick.
