Painting Intake, did I get the right paint?
I'm using this FAQ: https://ls1tech.com/forums/showpost....61&postcount=9
I have my duplicolor gray high build primer and I need to find adhesion promotor.
Base Coat: I have duplicolor Truck, Van, & SUV paint in ultra silver. It says it is an Acrylic Lacquer.
Main Color: I have a duplicolor anodized metalcast paint.
Question: I have two clears, which is the right one?
1. Duplicolor Truck, Van, & SUV Clear Top Coat. It is an Acrylic Lacquer.
2. Duplicolor Acrylic Enamel (in clear). It says it is designed to use over Acrylic Enamel colors.
I have no idea about all of these acrylics and lacquers and enamels etc...
Just my findings, after all the years of paint work I have done.
Best of luck!
I forgot to mention I'm painting an LS6 intake, which is plastic.
Sorry, man.
Pretty sure ls6 manifolds are made of a composite. I would use a good adhesion promoter. Search Bulldog or something like that. Parbreak recommended it to me when I did some painting on plastic and it worked really well.
Make sure to post pictures when done.
Originally Posted by parbreak
LS6 intake is a composite material that's bascially nylon. Use an adhesion promoter, not a self etching primer.
Can you tell me which one of those two clear coats I should use?
LOSE THIS.Main Color: I have a duplicolor anodized metalcast paint.
http://www.geocities.com/mrmtransam/intake/
Originally Posted by SweeTbone
Use the Top Coat Acrylic Lacquer and just use the Base Coat paint you have listed as your primary paint. Check out my write up, pictures included. I have the 4 cans of Duplicolor products I used for mine. The actual paint is all purpose paint and the clear coat is just "Acrylic lacquer Clear". The silver color I used says in yellow writing on it "Ideal for Trim Accessories".
It's the same color as my calipers, silver base coat with anodized blue over that.
