Need Advice....Wreck **PICS**
Any help would be greatly appreciated. If you could give me a round about price as to how much a shop would charge to fix that then please let me know.
That requires a new bumper, hood, headlights, front support brackets, fenders, and paint. That doesn't include labor. The body shop can give you an estimate after they look at it, but they will more than likely want you to buy parts through their retailers unless they're willing to work with you. If you have patience, a lot of those parts can be purchased from people on this site and ebay, which will become your second best friend (behind ls1tech, of course
)If you go the insurance route, they might total it, especially if it has frame damage. That may or may not be the case. It looks like you may have some, but not extensive. If the airbags deployed it's 99.9% likely that they'll total it.
So you have options, just trying to help you out. I'd weigh out the possibilities and financial situation though before I do anything.
Good luck with it.
As stated above you need a front outer nose or a short clip. If you can find a front nose or a car with verything from the bumper reinfocement out and up this will be best. However most camaros get totaled going forward pretty fast that usually is not an option.
Based on the overall shape of the car you have some frame damage or misallignment of the front unibody part of the car. Its not hard to fix but you need a frame bench
and ability to measure the car or when you bolt the outside to it nothing will fit.
When my car got hit and it needed only the outside stuff it was about $5000 for the shop to do everything and blend the doors which is about right for that kind of hit.
If you are on your own and there is no insurance to cover the loss I would tear down the front of the car bumpers hood and fenders and toss whats busted and broken and beyond repair. Save all the hardware and pieces that are salvage able. Find a shop that has a frame machine and have them come over and look at the car and give you an estimate to straighten out the front structure. See what you can do to locate used and aftermarket parts wich will bolt up which if you have some skill you can do.
you will probably want to test fit all the front panels and then have them painted off the car and install them yourself afterwards.
That is the best way to do the most you can yourself and save the most money.
I ran a quick value in NADA Super Clean 2000 with ~100k miles comes back at $6,925
retail. I've seen same car on here for much less. Weigh out what is the most cost effective plan.
PM me with any other ?s
I am willing to bet that if it is slightly twisted, it is not bad, or your radiator support, air box, and such would be out of wack/busted. It all looks pretty good, in accordance to the blow the car took. Obviously, it did not deploy the bags so the impact must have been a glancing blow, and not direct impact, which is more likely to cause serious uni-body frame damage. Even notice the front inner re-bar metal bumper was not badly damaged. I would leave it on until you measure, because if it needs any pulling, you can get some accurate pulls with leaving this on, while on a frame machine.
I suggest tear it down, inspect everything with your eye, and measure from the outer bolts holes on the inner structure, to the center of your shock towers, to see if the front end is square. Also, measure front to back of the front end inner structure. If it is off, then you might need a slight pull, but if the car needs pulled, it will not need much, if any, judging from the way the car glanced off the guard rail. Wish you were closer, and I could come over and help you get it squared up so you could do most of it at home and save some money. If you take it to a shop, the hourly rates get pretty expensive, so I would look to get all the parts I could on my own.
Personally, I would never go with aftermarket fenders, as GM are much better, and you will not have to haggle with cheap aftermarket crap that will not fit and lineup correctly. Good luck with whatever you decide, and if we can help anymore, please holler.
If you got no idea what youre doing, dont attept to fix it, just elave it be and have someone who knows what theyre doing, do it for you. if the rail or anything is twisted any they have machines and pullers that will pull out and bends and kinks.
