Painted my Intake
Bryan
parbreak
Edited to add the following.
I would advise following Parbreak's "how to" very closely. Some advocate lots of clear. I think that may have caused some minor problems for me. Also, do not let base and clear over-dry between coats. If for some reason you are interrupted and you cannot lay all your base and clear down at one time (allowing the curing times Parbreak recommends), scuff it with 400 grit and start over with base. My first mistake was not properly scuffing the base I let dry so I could remove a mark I made in the wet paint. The second might be applying too much clear.
Bryan
parbreak
I sanded the absolute hell out of it. You suggested a minumum of 400 grit if using high build primer - I went to 1000. I sanded the high build primer super smooth as well.
The silver base came out pretty good I think. I just wish I could watch someone paint something plastic like this once. I'm so afraid that I'm going to spray it on too thick, so I do it light and spread it out over 6 or 7 coats instead of 3 or 4. Maybe I'm doing too much misting which is causing it to be uneven.
Either way, the real problems arose when I added the anodized blue over the silver. It didn't come out nearly as nice as when done on my calipers. In fact, the first time I did the blue it was so rough the top coat would crumble off if you touched it. So I waited a week, then sanded it smooth again until some silver could be seen again. This time I think I laid it on too thick
I don't know. It looks like I was drunk and half-assed it when I really spent A LOT of time on it. Depressing.
That is something weird with the anodized blue though. Was it the same type of paint you used as the silver base?
And the anadodized blue is a Duplicolor Metalcast. The silver is an Acrylic Lacquer Duplicolor.
https://ls1tech.com/forums/appearance-detailing/611622-what-use-get-paint-off-intake.html
So when I use stripper/thinner, will that just take off the paint or does that take off primer as well?
BTW, I used that same blue paint for one of my projects, and came out alright.
http://img90.imageshack.us/my.php?i...build058xj4.jpg
http://img245.imageshack.us/my.php?...build059xb9.jpg
http://img408.imageshack.us/my.php?...build060fn0.jpg
It could soften the plastic and ruin the intake.
Use what you already have on there as a filler.
So all you need to do is just sand it smooth with 320 or 400 then apply 2 coats of a high build primer, then sand smooth.
If you still see dimples and it is not completely smooth then re-apply more primer and then sand smooth again. The smoother the primer is the smoother the base and clear will lay down!
Try to think of primer as liquid filler!
. But hey aleast you tried.
