SS Shacker hood
Old May 16, 2007 | 12:05 AM
618HAWK's Avatar
Default SS Shacker hood
My SS hood shakes like a shaker hood.
Just wondering if any one else has this problem. Hood was recently installed, while cruising down the freeway it will shake and float at the rear. Have tryed to adjust the front bump stops. There is no type of adjustment that can be made at the rear of the hood to prevent this for what I have found.
All gaps and body lines are flush, fits great, and yes this is a OEM hood.
Is this normal for the SS.
Not real worried about it, but I just do not want the undoo stress on the hood.
Old May 16, 2007 | 02:16 AM
ultraz's Avatar
you know what, I distinctly remember that bugging me about my hood. Dont really notice it anymore, I wonder if ive gotten used to it, or the shocks have setted at their resting position.
Old May 16, 2007 | 12:56 PM
Ls1CamaroGuy87's Avatar
Yeah, I had my oem ss hood installed and painted about a year ago, it fits perfect, but it definently vibrates at the back like you described, I have pretty much gotten used to it though. I think it is common
Old May 16, 2007 | 02:49 PM
Oso SS's Avatar
My SS hood shakes above like 85 or 90 mph, and my last SS (with 15k on it, no accidents or paint ever) did it too. So I'm guessing that's normal. It floating is weird though
Old May 16, 2007 | 03:54 PM
618HAWK's Avatar
Ok at least I am not the only one. Makes me feel better, knowing it is not something wrong. Just dont see any way to that it could be secured at the back. Unless I get in to some type of custom bracket or hinge modification.
This is the wifes camaro, dont have any problem like this on my T/A. Hood is rock solid.
Old May 17, 2007 | 01:14 AM
RickyMartinZ28's Avatar
My 4" cowl hood bounces and shakes until about 1500 rpm, but i have a hell of a cam, but nothing driving down the road, totally solid!
Old May 18, 2007 | 07:29 AM
twokss's Avatar
my hood doesnt shake at all. and i have a cam.
Old May 19, 2007 | 03:53 PM
f50nut's Avatar
same..no shaking here and 31k on the clock
Old May 19, 2007 | 04:31 PM
Shinigami2x4's Avatar
Mines Fiberglass and viberates to the tone of my right foot..
Old May 19, 2007 | 10:51 PM
KillerD's Avatar
Make sure your weather stripping is intact right where your hood sits down in the back.
Old May 20, 2007 | 11:05 AM
will69camaro's Avatar
Sex On Wheels
Mine shakes above 100, weatherstrip is new, hood is OEM no accidents. I hardly notice it anymore, gotten used to it.
William
Old May 23, 2007 | 08:20 PM
djsanchez2's Avatar
No shakes here w/ 52K on it.
Old May 26, 2007 | 07:57 PM
SpdFrk1990's Avatar
Never noticed mine shaking.
Old Jun 3, 2007 | 01:41 PM
m_ghonim's Avatar
mine shakes too once I get on the freeway or do freeway speed on streets. Its oem but been repainted
Old Jun 4, 2007 | 12:04 AM
MonochromeSS's Avatar
Mine will shake too at high speeds, dont know exactly what speed. But i first noticed it in the traps drag racing so somewhere between 110-120.
Old Jul 30, 2007 | 10:34 AM
AFASTYZFR1's Avatar
so, is it normal because it is a fiberglass hood? Any way to make it shake less?
Old Jul 30, 2007 | 11:42 AM
NightWindDriftr's Avatar
Mine shakes as well. OEM SS hood on a Z28. The shaking is very minimal and only at highway speeds. It bugged me at first but I got used to it.
One idea I had to control it would be to pad the rim of the fender (that the hood sits on) with something like weatherstripping. I don't know if it would work, but that should be enough of a buffer to prevent shaking coming from the engine bay.
I'm inclined that the shaking has something to do with the wind, too. If that's the case, there's little you can do about it. A grille might help baffle it.
Old Jul 30, 2007 | 11:50 AM
618HAWK's Avatar
I am thinking it may have something to do with the mix up of hood struts. Ie Z28 to SS hood. With out changing the struts to match.
Hood was swapped out but don't recall which struts I used, had both on hand, Z28 and SS.
Just a thought...........
