T-tops?
Old Aug 2, 2007 | 08:01 PM
  #41
johnson7454's Avatar
i would like t-tops cause that is just more paint you dont have to worry about...lol
Old Aug 2, 2007 | 08:07 PM
  #42
LS1powerhouse02's Avatar
and to be honest......99% of the time the people who talk about how much better hardtop cars are and how they would rather have a hardtop are those guys who have T-TOP CARS! They can go out and take their tops off on a beautiful day and enjoy it every once and a while. Believe me on days like that just putting your windows down dont do justice. I want t-tops so bad.
Brent
Old Aug 2, 2007 | 10:08 PM
  #43
RickyMartinZ28's Avatar
I'm glad I'm not the only person who has a leaky a-pillar... my rubber is almost new too....
Old Aug 2, 2007 | 10:31 PM
  #44
**** my car is a 2002 and i first noticed it leaking after washing it when it had maybe 5,000 miles on it! I want to convert my car to t-tops so i can atleast have an excuse when it leaks! haha
Brent
Old Aug 2, 2007 | 11:25 PM
  #45
bww3588's Avatar
i want t-tops so bad....i can taste it......
Old Aug 2, 2007 | 11:34 PM
  #46
Camaro396's Avatar
Originally Posted by bww3588
hell ill trade with you! seriosuly.....im in chillicothe.
the car in your sig? high 12s? ill trade
Old Aug 2, 2007 | 11:42 PM
  #47
bww3588's Avatar
i ment tops.....not cars....
Old Aug 2, 2007 | 11:46 PM
  #48
Camaro396's Avatar
haha i meant cars lol
Old Aug 3, 2007 | 08:13 PM
  #49
Jpack's Avatar
For the record, yes all Fbods were born t top cars. The Verts are a whole different ball game and structure is under the car. The side hardtop roof supports have a GM part number. See picture. Believe me I did a ton of research having an engineering background, before I hacked into my car. Also while in BG for the camaro gtg last year, Scott (Fbodfather) gave me the thumbs up and looked it over really close and also confirmed the born a t top car theory. Also for those complaining of leaks, you need to make adjustments. Keep in mind these are uni body construction. Without subframe connectors they will flex whether a hardtop or any other unibody car. With that said, some direction for adjustments can be followed.
1) If you can close your door with the window up and a dollar bill slipped between the glass and t top slides right out, you need to adjust the window. It should pull out with some force.
2) When I put my t tops on, I need to use slight pressure pushing downward on the top to latch it. This forms a very tight seal and stops wind noise. if yours don't do this and the latch arm moves very easy, you need adjustment. To do so, remove the a pillar covers and rear cover where the mount is. Loosen the 2 bolts on each and you will see shims in there. Adjust the shims by removing them and placing on top of the bolts. This will bring the mounts lower and make the tops tight.
Old Aug 3, 2007 | 11:55 PM
  #50
bww3588's Avatar
when im ready to do mine, im coming to you Jpack. ill assist, but i want you to do it. ill pay you.
Old Aug 4, 2007 | 06:35 AM
  #51
Jpack's Avatar
No problem. I have done a bunch of them.
Old Aug 4, 2007 | 11:04 AM
  #52
Jpack......what writeup did you follow? or did you just do it without one? Also do you have any pictures of your t-top conversion, preferably some close up pictures. If you do pm me or e-mail them to me brent_gorman@hotmail.com
Thanks!
Brent
Old Aug 4, 2007 | 12:22 PM
  #53
Jpack's Avatar
I have a write up I did. I also have pictures of one I just did. I need to mark them up with arrows and tags etc. Just been to lazy. I'll get it all up in a few days. As far as the write up, here is a link. It will make more sense when the pictures are up. The last one I did didn't include the body finishing because the guy was going to do that on his own. I have to update a few things in the write up, but it will give you an idea of what is involved. Here is the text write up.....
http://www.z28.com/forum/showthread.php?t=105495
Old Aug 4, 2007 | 03:31 PM
  #54
bww3588's Avatar
Jpack, on the writeup, what is #8 on the parts needed, "rear targa roof pannel"?
Old Aug 4, 2007 | 11:24 PM
  #55
It is that piece of the roof that goes from right behind the drivers window, over the top of the roof, and down behind the passenger side window. Instead of the whole roof like our hardtop cars have.......t-top cars have just that "piece" of the roof.
Old Aug 5, 2007 | 01:22 AM
  #56
bww3588's Avatar
no the only thing that hardtop cars have that t-top cars dont is the skin over the t-top bracing and what not.
Old Aug 5, 2007 | 01:51 PM
  #57
yes i know that. What i am trying to say is on hardtop cars it is all one piece. When you do the t-top conversion you usually just cut along that line and keep that piece you are wondering about on there. But it wont look 100% factory installed unless you buy just that piece that goes over the b-pillars and replace the one you cut. Understand?
Old Aug 8, 2007 | 08:58 PM
  #58
Jpack's Avatar
Pictures added to the write up. Done on a Firebird. Bodywork was to be completed by the owner. This was a budget conversion for him. Had the car back to him in 1 day.
