rear wheel flares
NOW, if you wanted to put flares on the front, it would be much easier. The front fenders are fiberglass, So to build a basic shape to add onto it....... sand the paint to bare fiberglass, or close....... build up the shape you want with fiberglass and a mold........ or simply using duraglass......... then FINISH with bodyfiller.
bodyfiller cannot be used to build things......... its meant to cover small blemishes on body panels, not make them.
I think it looks a little more aggressive, you just move the points where the body mounts to the poly/plastic body stuff out 1/2" - 3/4" in the rear by flipping over the bracket under the car and screwing it back in. on the front you remove the clip that holds the body panel to the plastic under the car and make a little flat pieces thats longer to push it out to the sides some.
