Painting Wheels?
and the powdercoating process eats away our wheels and can cause failure
painting is the best thing to do
a quote directly from trackbird:
My process:
I got a powerful degreaser ("Purple Power") and cleaned the wheel inside and out, wetsanded with 320 grit sandpaper, scuffed it with a wet maroon scuff pad using a surface prep agent ("SEM Soap"), washed it with soap and water, and allowed it to dry. Before painting I wiped the wheels down with a silicone remover and applied Bulldog adhesion promoter before topcoating with the rattle can wheel paint. I followed the instructions of the paint as how long to wait before clearcoating (in this case overnight, but most only need 1 hour). Basically treated it like any other painting job, only I used 320 because they were wheels.
It should be noted though, that my wheels were extremely dirty on the inside and I needed to use steel wool and lacquer thinner on the inside of the wheel to get it clean.
