Has anyone used Krylon Fusion on an intake manifold?
I've been researching paints etc. on www.duplicolor.com
They have a lot of good info. I'm painting my intake manifold satin black, then burnish it lightly with OO steelwool. I've done it before on other parts and it looks great.
It sorta looks like wet sanded paint before you polish it out. I just like the duller look on this stuff.
Fusion is tough paint to work with. If you make a mistake, chemical stripping is very difficult. I would make sure your area is 100% ready for paint before using it. Also, with the shape of the intake, its going to be tough to wet sand the unit for the right look. All things to consider.
man ...i just got a PM saying I had a word spelled wrong in my Sig * deleted now too much hasle* and now after reading my last Q I see I muffed up again.....guess typing after staying up all night with my newborn isn't the smartest thing....
Fix.. thanks for the info I'll file it and be sure to try it on my next paint project.
Hope I didn't upset the applecart.
Congrats on your newborn! Thanks for serving, too!
Congrats on the newest addition to your family!!
[QUOTE=bsf;8366605]Fixvet, good to see you found Parbreak’s write-up. I think following that write-up very closely will yield very nice results for rattle-can work. Prep is extremely important. I cannot speak to longevity, since I only did mine this year.[QUOTE=bsf;8366605]
Cool! Yeah, I'm getting some great feedback from alot of guys on several forums. Hey, we can never have too much info, eh?
Man, your TA motor looks very cool. You did a good job modded the C5 frc's I like the sanitary look of your engine bay.
I spent a ton of time on my engine bay, and learned much. First time I did anything like this. If I did it again, I would do things differently. I would keep the metal polishing to a minimum; too much work. If not cost prohibitive, I would pay a shop to chrome the TB, MAF, AC accumulator, and other parts. If I did not chrome a part, I would just paint it (not the AC accumulator). Considering all the crap I painted (intake manifold, valve covers, coil brackets, front engine cover, power steering pump bracket, power steering cooler, belt tensioner, air filter assembly, water pump, etc), I should have bought or borrowed a sufficient spray gun and compressor. I could have re-painted the engine bay w/ real automotive base + clear. Next time around I would do the frc’s and air lid myself. Bla bla bla.
The important thing is that Parbreak wrote up an excellent tutorial, and I think if followed you can achieve pretty good results w/ spray cans. If you can use a suitable spray gun, you may want to investigate that route, though. Regardless, do not f**k yourself by skimping on the prep. Sand that intake down smooth and clean it properly prior to applying adhesion promoter. Some people do not put the time into sanding the texture out of the intake before painting, and I do not like the result at all.
