sailpanal replacement ( do it yourself )
Where are the names and numbers vetteman?
I have been told to go pound sand by a HUGE Chevy dealer and a Pontiac dealer, despite having a claim # and pre-approval from Government Motors.
So do tell...where is this place?
And to the OP, thanks man, you have ***** of brass to do this and you have given many hope for this ridiculous problem which plagues our most cherished.
https://ls1tech.com/forums/paint-bod...-sale-now.html
"Just finished install today. turned out even better than I had hoped - I was concerned because mine is a 35th LE that used to have a red sail panel... this one looks much better. Fit was really good for aftermarket. Was worth the wait. Thanks.
Roger
PS Didnt take pics yet because its kinda dark and you cant see the fiber. You want any pictures of it installed?"
Do you have any picture to share?? Before or after?
Please do keep us posted with your progress!
I've just ordered a new replacement sail panel from 6LE design today! They are running a special this month, so I took the plunge.
Although I probably wont install the new panel until fall.
What it looked like before:
The replacement panel back from paint:
My best friend and I removing the old panel:
We just used a hammer to start the hole on the side, and then crowbars to pry:
All finished:
I had a battery powered reciprocating saw and a couple extra battery packs that did the job. Take lots of blades, you'll want the longer ones.
Once I got the sail panel home, I spent a couple days with the angle grinder removing the steel and saving the fiber glass panel.
Tearing off the old sail panel was a daunting task made easier by one of those oscillating saws which easily cuts the fiber glass. I cut it out all around inside where the wide beads of glue are so then all I had to deal with was the glue itself. Removing the glue was made significantly easier by using a heat gun to soften it as I pushed through the glue with a 3" wide putty knife I sharpened.
Next off to the body shop to have the new sail panel painted and prepped. They are charging me $450 to prep and install the panel. When they explained the amount of work that still needed to go into the panel, it sounded fair. Paint isn't cheap, they had to fill a couple spots, sand the whole panel, prime the back side, paint the front, clear coat the front etc.
So all in all, I have about $575 into this project including grinder cutting wheels and everything. IT LOOKS GOOD! Hope i don't get bubbles.I shouldn't, the sail panel was sitting in the scrap yard for years and had no bubbles.
Ken
That sounds right! I just had my panel replaced also (read/see it in the sticky).
I supplied the panel ($600 w/free shipping). The body shop cost me $525 for everything else (removing the old, prep, paint, clear the new, and install of the new panel).
