Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS: 383 block/pistons/rods, New GM Cat, MSDOpti, BFG Drag Radials, Magnaflow etc
Old 08-26-2010, 11:21 PM
Tireburnin's Avatar
Default FS: 383 block/pistons/rods, New GM Cat, MSDOpti, BFG Drag Radials, Magnaflow etc
Category: Engine - Power Adders
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): CA
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Non-LS Part
FS: 383 Block, forged pistons/rods, New GM Catalytic Converter, GM847 Cam, Alternator, MSD Opti, Comp Lifters etc
I have been clearing out my garage and getting my projects finished or ready to sell.
TONS MORE PICTURES:
http://picasaweb.google.com/snvent/L...W6sKOa6YL2sAE#
SRP Forged Pistons and 6.0 Forged Rods - $319 SHIPPED
These pistons came out of a 383 with about 30k miles on it. Pistons are in good condition and rods look fine. Piston part number SRP 138103 are over $560 new. These are dished pistons in 4.030 size and about 10.5-10.7 compression with 52cc heads. Rods are Eagle I-beams and have Eagle rod bolts.
383 Lt1 Block - $99 PLUS SHIPPING
This 383 block has about 30k miles on it. The bores look good and have only minor wear. The deck is clean and I believe it has not been zero decked yet but I don't remember for sure. The block has already been clearenced for a 3.75 stroke crank. The crank broke in this engine but there was no damage. There is slight wear in the front main and it might need a larger bearing. I will throw in a Melling M155 pump with the block.
140 AMP Alternator - $45 PLUS SHIPPING
This alternator came off a 97 transam. Mileage is under 5k and it is in very good condition. 140 amps and no core is a big savings over the $130 this costs new. Part number from napa is 66180.
BFG Drag Radials on Transam Wheels - $125 PLUS SHIPPING SOLD
The tires have fairly low mileage and were only used for track use. They have a few track events on them, but still have plenty of life on them considering how little tread depth they come with new. Shipping looks to be about $20-30 per wheel. Tires are 255/50/16 in size.
BRAND NEW GM Catalytic Converter 93-95 Single Cat - $185 PLUS SHIPPING
This is an absolutely brand new GM cat...ordered from the dealership with receipts. Spent over $581.00 with a discount. List is well over $700. This car is brand new down to the stickers on the tubing. It is a direct bolt in for 93-95 single cat v8 cars (camaro and firebird). Shipping won't be cheap unless I mark and cut one fo the tubes off.
Magnaflow Catback Exhaust - $100 PLUS SHIPPING
This exhaust is for 93-97 LT1 cars. It is complete but will need new hangers welded on because the originals get ripped off (there is a hole where one was that needs to be welded shut).
1LE Intake Elbow - $35 PLUS SHIPPING
No rips or tears. Looks and works fine. It is missing the rear worm clamp (but one from your stock elbow is the same). See pictures in the album.
LT1 Poly Motor Mounts - $35 PLUS SHIPPING
These mounts are in great condition and show no signs of sagging. They are fairly low mileage (15k). They are already assembled in their clam shells and ready to go for install. See pictures in the album.
Stock LT1 F-body Oil Dipstick - MAKE OFFER
Stock LT1 Head Coolant Crossover - MAKE OFFER
MSD Opti Cap and Rotor Kit (New) - $95 PLUS SHIPPING
The MSD opti cap and rotor kit is brand new in the box. It was only opened to look at it and all parts are there. These are $140 new plus shipping. Part number is MSD 84811 and it is for vented optis (94 or 95 to 97).
GM LT1 MAF Sensor - $40 SHIPPED
Stock sensor with 100k miles on it. It has no screen installed and was working fine when removed.
GM 847 Cam - $169 SHIPPED SOLD
This is a big cam that will rev high and can make 400+ rwhp with a good set of heads. On stock heads it can make 350rwhp. Specs are 234/242 .539/.558 (1.5 Ratio) 112 and .575/.595 (1.6 Ratio). The cam has about 15k miles on it and is good shape. Part number Crane HR296-2S-12.
Stock LT1 Intake Manifold - $45 PLUS SHIPPING
The manifold is stock except the throttle body bores are bigger for the 52mm throttle body above. It is in good condition. I can include a set of stock fuel rails and injectors (from a 97 camaro) for an extra $25.
TONS MORE PICTURES:
__________________________________________________ ____________
Hooker Coated Long Tube Headers - $369 SHIPPED SOLD
These headers came off a 97 LT1 F-body. They are coated Hooker long tubes and are the race style (no emission fittings). The headers have nice coating and few dents. The coating has turned orange at the bottom from heat. Includes header bolts.
Offroad X-pipe w/ Bullets and Heddman Crossover - $140 PLUS SHIPPING SOLD
This x-pipe will bolt right up to a set of hooker headers. It has bullet mufflers and a Heddman x-pipe. Includes mounting brackets. Shipping will require cutting but should cost about $30ish once cut up. I mark the pipes well before cutting so aligning and welding is easy.
Comp Cams Pro Magnum Rockers (1.6 ratio) - $175 SHIPPED SOLD
These rockers are for a 3/8 stud and they have about 30k miles on them. They are in nice condition and include the poly locks. These rockers are well over $350 new with the locks. These are non self aligning rockers and will require guide plates. I can throw in a set of Comp guide plates for an extra $15. Includes 16 rockers and locks.
95-96 LT1 Timing Cover (Cam Sensor) - $59 SHIPPED SOLD
This cover is in great condition and includes the cam position sensor. This is for an OBDII ECM. This is the cover that everyone is using to convert to the LS1 PCM because it requires a cam position sensor.
MSD Coil (almost new) with ICM - $35 SHIPPED SOLD
This coil was only used for about a 1000 miles. Replaced the coil only to find out it was the opti. Black in color and includes a stock Ign Control Module from a 97 camaro. Should work fine for you. Part number is MSD 8231 for 92-97 LT1.
BMR Front and Rear Black Sway Bars - $175 PLUS SHIPPING SOLD
These sway bars are in great condition. Black with red poly mounts and upgraded end links. The bars are solid (not hollow like some others). No issues with them at all. These bars will fit 1993-2002 camaro or firebird chassis. The front is 35mm and the rear is 25mm. New these are over $360, so you are getting them at half price.
BBK 52mm Throttle Body for LT1 - $169 SHIPPED SOLD
This throttle body came off a 97 LT1 camaro. It will work for corvette but you will need to swap the IAC sensor on the bottom with your stock one. This TB would be worth some good power on a built car.
O2 Sensor Extensions and Rear Simulators - $50 SHIPPED SOLD
The extension harnesses are 24 inches and are in good condition. The simulators plug right into the rear 02's and look good. These are off a 97 camaro. Pictures are in the album.
LT4 Knock Module - $49 SHIPPED SOLD
Came out of a running car. Works great. See pictures in the album.\
Comp R Lifters - $119 SHIPPED SOLD
These lifters have about 30k miles on them and look to be in good condition. The oil was clean and these are ready to go. These are the old style (ring insert not the pressed in clip).
Lucas 32lb Fuel Injectors (8) - $145 SHIPPED SOLD
These fuel injectors are almost new and are rated at 32lbs per hour at 42.5 fuel pressures. Here is more info about them:http://www.racetronix.com/621020.html Part Number D1720BA. These were almost $300 new and they have very low mileage.
Comp Cam 206/212 at 112LSA Cam - $105 SHIPPED SOLD
This is a very mild cam that is great for someone that has to pass smog. It is mild but will still make decent power. It will be about .500 lift with 1.6 rockers or .480 lift with 1.5 rockers. It has about 15k miles of use.
Old 08-27-2010, 02:41 AM
jay7199's Avatar
shiping cost for sway bars to 78613 please.
Old 08-27-2010, 09:51 AM
Tireburnin's Avatar
I will weigh them and send out shipping quotes to all that have asked this afternoon.
Thanks
Old 08-28-2010, 09:01 AM
Tireburnin's Avatar
Bump for the weekend
Old 08-28-2010, 09:47 AM
94'BLKBRD's Avatar
My brother is interested in the sway bars, I believe he pm'd you.
Old 08-28-2010, 11:26 AM
somZ2801's Avatar
pm sent on headersand xpipe setup
Old 08-29-2010, 12:40 AM
Tireburnin's Avatar
Updated for sold items
Old 08-29-2010, 10:40 AM
Tireburnin's Avatar
bump for today
Old 08-30-2010, 11:17 AM
Tireburnin's Avatar
Updated for sold items. thanks
Old 08-31-2010, 10:48 AM
Tireburnin's Avatar
Updated for sold item. TTT
Old 08-31-2010, 10:28 PM
Tireburnin's Avatar
Old 09-01-2010, 10:21 AM
Tireburnin's Avatar
Bump for today....make me some offers
Old 09-02-2010, 11:20 AM
Tireburnin's Avatar
Bump for lowered price
Old 09-02-2010, 11:26 PM
MrK
MrK's Avatar
what would you be willing to take for the 847?
Old 09-03-2010, 11:11 AM
Tireburnin's Avatar
Sent you a PM. Thanks
Old 09-04-2010, 11:01 AM
Tireburnin's Avatar
Bump for today
Old 09-04-2010, 03:58 PM
Tireburnin's Avatar
Old 09-05-2010, 12:10 PM
Tireburnin's Avatar
Bump for today
Old 09-06-2010, 06:23 AM
hitmanws6's Avatar
bump for you, would have bought this cam off of you if it was around a few months back
Old 09-06-2010, 07:49 AM
smb72's Avatar
still have the exhaust
