FS 383 ci LT1 cast iron Nitrous Engine Motor
Category: Accessories
Price: $4500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): FL
Item Condition: Used
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
Asking 4500 obo
Less than 5,000 miles LT1 motor cast iron block 383 ci dyno 489 hp to rear wheels using a th350 tranny and 10 bolt rear end
Motor is currently still in car (94 camaro) and in perfect running condition, Motor will be pulled when buyer is found. Willing to even give ride in car before.
For serious buyers only will do a compression leak down test in person so you know motor is in great condition and give cam/head numbers. (call/text)
Motor was blueprinted and dyno flow
LT1 trick flow heads
Heads are studed, multi-layered steal head gaskets
Nitrous Cam
3.75 in forged stroke crank
6 in H beam forged Rods
JE forged pistons 4.030 bore
Hellfire piston rings
Ceramic coat tri-armour bearings
4 bolt splade end caps billet steal
Jam performance intake manifold for carb application, but carb not included
Probillet distributor
MSD wires, NGL plugs
Lunati timing chain
electric water pump
7 quart mildon oil pan
Will also include 2800-3200 10in stall for th350 tranny
Mylilpony- All you need to convert to a 6 speed is the flex plate, clutch, and manual tranny. It will all hook up. He is including the stall from the TH350(I think he had the stall custom made for this msetup and paid like 7-8 hun for it), but if you go manual you can always sell the stall on here for a few $$. Dyno numbers where all motor.
Im helping a friend sell it by listing it on here. He told me 4500 obo, He's spent numerous of thousands of dollars on this car and is now going to a different motor which he just bought. if you just wanna throw out a number thats not a low ball but a good deal he may take it. the motor really is top notch.
