GZ motorsports VP104 Race Vacuum Pump w/Pulley and Baffled Vented Catch Can! LikeNew
Category: Engine - Power Adders
Price: $550
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Here are the descriptions directly from their site.
VP104N New Design "Super Pro" Series Vacuum Pump, Tested at 33 CFM@5090 RPM, 24” hg. Inlet & Outlet on side of pump. Pulley and brackets not included. 6.5 lbs $419.00
PN Description Price Qty
VPP403 7.5" 6 groove Serpentine Vacuum Pump Pulley $115.00
Aluminum 2.5" Diameter x 9" Tall Double Baffled Breather Tank with 1/2 NPTF welded inlet boss on each side perpendicular to the mounting plate. A K&N type filter and clamp are provide along with an easy to use 1/4" pipe drain. Comes with (1) #10AN straight fitting and (1) pipe plug. The attached mounting bracket has (4) 1/4" holes designed to bolt to a flat surface. 2 lbs. $89.00
So total shipped new was $655 +fittings and hose =$695. Will let go for $550 shipped.
FWIW, this particular pump has been recommended for 750hp+ applications. 400HP-700HP has a different P/N recommendation. http://www.gzmotorsports.com/vacuum-pump-guide.html
