Notices
HPTuner software in stock.
Old 01-07-2009, 02:30 PM
BJSS25's Avatar
Default HPTuner software in stock.
Any sponsors have it in stock that could possible overnight or get to me by Friday. I need the standard version for $499.
Old 01-07-2009, 02:34 PM
jetlag's Avatar
Message the new sponsor from KYSpeed... marksls1ta, he has some in stock and ready to go.
Old 01-07-2009, 05:55 PM
LS1TECH Sponsor
foff667's Avatar
PM sent
Old 01-07-2009, 06:20 PM
poconojoe's Avatar
Originally Posted by foff667
PM sent
If you want to use HP Tuners Suite as a scanner, do you have to use any of its credits, if you haven't programed that vehicle with it?
How about if you want to use it to do a crank learn?
If I have 2 PCM's for the same vehicle, would it require 2 more credits to do the second PCM?
Old 01-07-2009, 07:59 PM
BJSS25's Avatar
Thanks Guys I was able to find at Speed Inc and its ordered.
Old 01-07-2009, 09:09 PM
LS1TECH Sponsor
foff667's Avatar
No
No credits needed either, its done through the scanner.
If you license the year/model license no. If you are doing single vcm licenses each vcm you want to tune would need to be licensed.
Old 01-07-2009, 09:16 PM
poconojoe's Avatar
No
Thanks
Old 01-07-2009, 09:37 PM
Engine_HP's Avatar
how about if i flash the file in both the pcms ?
Old 01-07-2009, 09:41 PM
LS1TECH Sponsor
foff667's Avatar
You still need to have the license for the pcm's, each pcm has its own unique serial number embedded into it.
-Bill
Old 01-07-2009, 09:42 PM
poconojoe's Avatar
I think they lock it to the vin and the PCM's serial number
Bill beat me to it, but i was right
Old 01-07-2009, 11:02 PM
JonCR96Z's Avatar
Why do you need it by Friday?
Old 01-08-2009, 08:32 AM
BJSS25's Avatar
So I can Log some runs on Sat since it will be warm out, my car has kinda like a 1 second delay when launching off the converter. Like its boggs then it takes off. I am trying to see if its the timing setup, VE and MAF tuning. All the torque management has been removed but the trans abuse mode hasnt been disables but since the values are 0 I was told that isnt causing the delay. I have been so busy its hard to get down to my tuner so he can log and do some testing. So I decided to just buy the software and try myself with the help of others.
