Speed density replace MAF
Old Nov 18, 2008 | 10:27 AM
Sigforty's Avatar
Default Speed density replace MAF
Does anyone here know what size pipe I can use to replace the MAF? I am wiring in an IAT sensor instead of my 5 wire maf. I want to pull the MAF out and replace it with a piece of pipe, but am not sure what to go out and by.
Old Nov 18, 2008 | 03:27 PM
ringram's Avatar
Measure it dude, I think its 4" or 90mm somewhere around there.
Old Nov 18, 2008 | 03:42 PM
AFASTYZFR1's Avatar
3.5" diameter aluminum tube
Old Nov 18, 2008 | 05:28 PM
jimmyblue's Avatar
Moderator
If it's a one-way trip you can just hog the hell out
of the MAF and nobody'll be the wiser. Gut it out
to the shell.
Old Nov 18, 2008 | 05:39 PM
98Camarod's Avatar
^^Then you can't sell it. It's 3.5"
Old Nov 18, 2008 | 07:54 PM
DaveX's Avatar
I'm pretty sure I used a piece of 3" pvc that measures 3.5" on the outside.
Old Nov 19, 2008 | 09:55 AM
Sigforty's Avatar
I will have to look into the PVC, but if I want some Aluminum tube it looks like I have to order it. Thanks for the info folks.
Old Nov 20, 2008 | 12:46 PM
Fb0dy0nly's Avatar
True but if your going for "stealth", this a good idea
Old Nov 20, 2008 | 04:21 PM
98Camarod's Avatar
Right.....what about the big *** turbo or supercharger thats in the engine bay?
Old Nov 21, 2008 | 08:08 AM
Sigforty's Avatar
Or direct port nitrous kit with a standalone. Not to mention the loud exhaust. I am not worried about hiding if I have a MAF or not. I really do not want to destroy the 120+ dollar piece if I can replace it with a 10 dollar piece of pipe.
Old Nov 29, 2008 | 01:12 PM
Boosted in the rear's Avatar
Replace the MAF with 3" pipe, then tuck the MAF cable and connector out of the way.
You need the pipe to be 3.5" long, 3" inlet and 3.5" outlet
