If Catalytic deleted...
I'm still curious as to what the CAT overtemp AFR table does? Is that the AFR that is commanded when a certain temp is detected or is that the lowest afr that can be attained when a certain temp is detected?
if a vehicle does not have a cat how does the pcm monitor the temperature?
prediction based on motor load, AFR and so on.
Setting the COT EQ value to the same as your
commanded PE is a pretty harmless way to go.
In the process of tuning it. ANY Power Enrichment is only done at WOT. The mid range open loop towing, hard driving but not wide open is ALL done by CAT protection.
Let me tell you it runs rich. 11.8-1.
Not really sure what GM is thinking but the stock VE table is stupid lean on top and pig rich on the bottom.
Looks like GM uses Cat protection for more than cat protection.
Stock truck, not even a K+N filter.
You should see the logs....The Arabs love me at the pump!
