My LS2 is not healthy
Old Dec 13, 2008 | 10:11 PM
redgto4u's Avatar
Default My LS2 is not healthy
Here's the scoop:
About a week ago I made a few nitrous pulls all the way through 3rd gear...about 140. The car did not miss a beat and ran great. When I got off the highway I smelt some oil burning. Turned out I blew the dipstick out and oil went everywhere. Car ran fine the rest of the 30 minute drive home. Not sure why the the crankcase pressurized enough to blow out the dipstick. The only thing I can think of is that I have a lot of blow-by or my pcv setup is not doing the job. Basically, my pcv setup consists of one autozone breather tee'ed into both valve covers. As for the blow-by look below.
So the next day I went out and hosed down the engine bay to clean it up. Later that night I took the car out and it was stuttering/missed under part throttle until it got hot. I figured that something must of got wet and it would clear up...which it did once it got warm.
I've driven the car about 3 more times and it still runs like *** when its cold. Idles great and still pulls hard at wot. Part throttle it misses though.
So I pulled the plugs and did a compression check. All the plugs look good and the compression numbers were at 185 except for one was at 175. This one was like that months ago too. I also ohm'ed out the plug wires and they all checked good. The oil looks fine and so does the coolant. Does not smoke or burn any oil that I've seen.
Tomorrow I'm going to hook up the scanner and see which cylinder is misfiring. I also plan to clean the maf sensor...sng's. As of right now the only thing I could think of is a coil pack going bad or I need new wires.
Any other ideas??
Old Dec 14, 2008 | 10:19 AM
ssvolvo's Avatar
Time for an engine health checkup.
Myself I would warm the engine up and perform a leakdown test.
Scan it second.
Hope for the best.
Old Dec 15, 2008 | 11:59 AM
STAGEUP's Avatar
This doesnt sound good. Everytime ive seen a dipstick blow off, i've seen it lead to piston damage. Good luck
Old Dec 15, 2008 | 12:44 PM
1bad lad's Avatar
u broke a piston sorry to have to tell ya that. its ok many of us have done it.
Old Dec 15, 2008 | 02:28 PM
redgto4u's Avatar
update!!
Before running the scanner I loaded my n/a tune back into the car...I wanted to eliminate a possible problem with my n20 tune. Ran the scanner on the n/a tune and the car was running fine again!!
Looked at my n2o tune and come to find out, I forgot to disable ve like I did in my n/a tune.
As for the dipstick blowing out..I'm going to do a breather filter for EACH valve cover instead of tee'ing both covers to one tiny *** breather that is probably dirty...
I doubt there is broken piston at this point. All the plugs looked brand new. If something came off a piston then the plug would atleast show some kind of impact.
Old Dec 15, 2008 | 10:53 PM
fuseone's Avatar
yea i dont see a piston being broken being that all his compression numbers were basicly the same and even the 175 is well in range with the rest.
Old Dec 17, 2008 | 12:41 AM
1bad lad's Avatar
if there is enough pressure in the crankcase to push out the oil dip stick then somethin is fucked up. i've seen them ******* crack and and have good compression readings. funny thing is do u realize how much higher the cylinder pressure is when its actually running. and there has been many people that've blown their **** up with 150 kits. if the tune up is fucked up then damage is very easily done. when an engine detonates the cylinder pressures are almost 10 times higher. yea that'll break stuff and cause oil dip sticks to blow out....or maybe i'm wrong who knows
Old Dec 22, 2008 | 12:37 PM
273sunsetZ's Avatar
my busted piston cyl. showed a compression of 35lbs...lol...
