just got my efi live. you all want to check me tune?
i had my car tuned by a local guy that i cant say enough good things about. its a 98 cam only car that has a hsw dry plate thats set to pull 5* at 158*
i bought efi just so i can data log and make slight changes needed be. i think i did it right. i pluged it in to the car then went to flash then read calibrations. then saved it.
im gonna try and attach it see if it works.
one slight issue i have is if im in 1st or 2nd and im real light on the throttle when i let of and go in to neutral and cost it some times goes lean (over 17.1) and some times stalls. also the issue is when i go in to neutral and coming to a stop some times it will dip to 400 and then fix its self.
Do you have a wideband? You really need one to do a complete tune.
I log a number of items. Spark, Injector Duty Cycle, MAF (if you have one- I do not), IAT, RPM, Retard due to knock, VSS, ECT, TP, MAP, O2's-(I do not have any)+ others. It depends on what I want to tune. I have an idle log just for setting RAFXX.
Good luck. Have you read any tuning info? I have been tuning my car for years. After every mods like headers, cam, heads, etc.
Bill
Bill
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
its been dyno tuned by my tuner, so its runs great. i have a wideband but the display is on my microedge nitrous controler. a/f at idle is 14.7 and bounces around up to 16. and wot n/a is 12.8-13.1
one issue i have is after teh car is warm and its been driven hard the idle will then want to dip and wants to stall. i was doing about 20mph around a corner and put the clutch in and turned the wheel and once i got stright it stalled.
i dont have a log of it but does any one have a pid file saved they can put up so i can just use thoes things to log
i also adjusted my tune slightley from what my tuner left it at
take a look see if any of the idle stuff looks out of wack
when i log rafig do i let it idle or to i drive it around? and what table would i need to adjust
i changed a few things this morning so this is my latest tune file (havent driven it yet)
Both, use your preferred filter(s) then
add the logged RAFIG value to your desired airflow table.
Make changes to the ECT area in which you are having trouble in.
"After the car is warm and its been driven hard the idle will then want to dip".
At what ECT are you at when this happens?
Having the cold start areas inline will prevent soaring cold start RPM.
i have no issues with it cold just when hot.
like after a wot run ill put the clutch in and go in to neurtal and then thats when it wants to dip or stall.
what do you mean by the filters?
ok im lost, so log raifg act ect. drive it get the idle to fall then put it threw the filter?
a step by step would be great, this is where my tuning skills show that i have none
Make sure your TP% is 0 when the throttle is closed.
If it is not you will need to reset the TPS.
TPS reset:
with key ON engine OFF - unplug the TPS for 30 seconds
turn key OFF - plug TPS back in
Here are some basic PIDS for you.
IDLE.txt
Rename it IDLE.pid , so you can open it with EFILive and
add what you usually log that is not there (calc.pids for WBO2, ect.),
but don`t exceed 24 channels.
When it happens again look over and remember at what ECT this happened.
You can filter out the lower ECT range where there is no problem.
Save the log before you filter so you can revert back.
__________________
TPS reset:
IDLE.txt
__________________
No,
at the ECT, if RAFIG is over .03 or under -.03,
Add the high logged RAFIG values to {B4307}
Look here for more on Idle Tuning
Example:
Example:
![](http://i235.photobucket.com/albums/ee259/whitespar/RAFIG-1.jpg)
