??????ls1 edit or not?????
Old Oct 12, 2003 | 11:48 PM
KEVWS6SPEED's Avatar
Default ??????ls1 edit or not?????
I got a 98 trans am ws6 with catback exhaust and o2 simulators and i will eventually do alot more stuff
but should i get ls1 edit or something else, and what else will i need to get to go along with ls1 edit or soemthing eles thank you
kev sorry i dont know that much just learning thanks you
Old Oct 13, 2003 | 12:28 AM
Colonel's Avatar
Default Re: ??????ls1 edit or not?????
LS1Edit rocks. You'll need a laptop computer (preferably one with a serial port.) Get Autotap too.
Old Oct 13, 2003 | 01:30 PM
whats autotap?????
and what does it do?
Old Oct 13, 2003 | 03:13 PM
TILEMAN's Avatar
Autotap is a scan tool. It will give you info like timing, knock retard, O2s, fuel cell info. plus hundreds of others.
Old Oct 13, 2003 | 07:05 PM
Wildman's Avatar
whats autotap?????
If you plan on doing a lot of upgrades to your car (engine/tranny), then definately get LS1-edit.
Edit allows you to program your cars on-board computer to customize it (fine tune it) to your needs. The problem with EDIT is that it is not a scanner, meaning you can't tell after you made your changes how exactly you affected your car.
Thats were AutotapEFILive (or others) come in. You plug it up to your car while your driving and depending on the scanner, it reads (takes measurements) of things like STRIMS, LTRIMS, RPMS, SPEED, Incoming Air temp and so on, straight from your car.
For EDIT and AUTOTAP you will need some type of computer to run these programs. Preferably a laptop that is a Pentium 2 or better.
Old Oct 13, 2003 | 11:42 PM
wildman???????
is there anyway those touchscreen dvd player units that flip out of the dash could you like put these programs on them???
Old Oct 13, 2003 | 11:50 PM
blk~2000~Z28's Avatar
wildman???????
If they have a processor that is equivalent or better than a Pentium II I would think yes. But since most dvd players lack a CPU like that and an operating system the answer is no.
Old Oct 14, 2003 | 12:38 AM
rphinney's Avatar
You could always use a laptop linked to the video port of the screen but if you already have a 14 inch laptop screen you would have to be a retard to look at tbe little screen!
Old Oct 14, 2003 | 09:45 AM
you guys are right just get lap top anybody know where to get ls1 edit and autotap from? those are the best programs right?
thanks
Old Oct 14, 2003 | 10:19 AM
jrp's Avatar
jrp
SN95 Director
thanks
im in the same situation, you get ls1edit from www.carputing.com. and also get in on the TR GP for autotap and efilive. i got the efilive pro edition.
bottom of the page:
http://www.thunderracing.com/index.c...tegoryid=1135.
im just gettin a cheap lap top; p3 500, 128ram, ect. you dont need something really powerfull to run edit and autotap.
Old Oct 14, 2003 | 04:44 PM
ls1 is the best one out right? or is just preference?
Old Oct 15, 2003 | 02:35 PM
Colonel's Avatar
LS1edit can do the most, yes.
Old Oct 15, 2003 | 07:54 PM
what do i need autotap for??? what exactly?
Old Oct 16, 2003 | 01:27 PM
You need autotap to use as a diagnosis tool. You can drive your car around and due simple driving as well as some WOT runs and see what your car is doing (i.e. KR, air/fuel ratio, water temp, etc.). From this info you go to LS1edit and change timing, fan activation, fuel curves etc. so that your car runs at its best temps, air/fuel ratio, and no KR. I F-ed up and bought HPPIII and will be selling that shortly to pay for edit. But I bought Autotap from Thunder and will be playing on that for a while before buying LS1edit, I am not that confident in my programming abilities.
Old Oct 16, 2003 | 06:04 PM
01Z0H6's Avatar
When i recently had my car "custom tuned" by Chris Robinson (Dallas Tx.) he literally "downloaded "my factory settings (took approx 15 min.) then went & tweaked them with LS1 Edit. He then "uploaded" the new settings & plugged up his GM Scan tool (Some Huge handhelp device)
& we drove around. Part throttle, WOT, from a roll, top speed ,he did it all!!!
Went back & he plugged up the lap top again & "tweaked" some more. we did this 3X til it was perfect. I am no computer guru so i leave that to the pro's.
Anyway, it is a mod that you will definately notice.
My .02......
