Help. a/f 10.0???
I was still able to put a car length racing from a 60ish roll in 3rd to about 90......on a 08 c63 amg immediately after the dyno....somehow it doesnt all equate.
Could there be anything wrong with my motor if I have been running this rich for a while? I havent hooked up the spray yet so dont worry about that part.... what should my a/f be at and how much more power do you think Ill make?
Thanks
If you're going to spray a dry shot, then the tune will need some more work to be safe, but if the nitrous will be a wet shot, you can keep the NA tune in a normal NA range, and setup the fuel jet on the nitrous to keep the nitrous afr correct seperately.
Thanks
Definitely need to lean it out though either way
Your tune could be total garbage. Do you have someone who can download it from your vehicle and post it up?
The dark smoke is most definitely a rich condition, the white can be any amount of things.
See if you can have someone look at your tune first before jumping to any conclusions though.
-Eagle
But now theres a whole new issue.
