Dying at stops after intercooler project
Now, I designed and built an intercooler setup for my Whipple twin-screw SC. Startup is even worse as it will die on the first two startup tries before it even gets a chance to hunt big time for idle on the third try. Also, the most anoying part, the truck dies at stops. ***It only dies from first gear stops before it has a chance to shift into second gear. If I come to a hard stop when I had been running in second gear, it will not stall out and things are fine.
Here is what I have concluded and worked on:
Over the modification period of the truck, the intake air has had to take a longer and longer route before it finally gets into the intake manifold. i.e. through a SC now through a SC and intercooler and some plumbing to get to the intake manifold. To address the dying at stops situation, I adjusted the Airflow Decay in Drive table in LS1edit...to my suprise even at maximum input values the rpm's would still drop and the truck would eventually die--comming from a first gear stop only
I next logged the IAC readings from a second gear stop that works just fine, versus coming to stops in a first gear scenario. The IAC counts are much higher in second gear and do not decay as nearly as quickly as a stop in first gear. My idea is that it is allowing more airflow through the IAC coming from a stop in second gear than compared to the amount of air the engine gets coming from a first gear stop. I have tuned all of the Airflow tables in Edit with no luck. I am pretty sure I just need to keep the IAC open longer when stopping from first gear. I thought that is what the Airflow Decay in Drive table was for, but it did nothing -even with the maxed out values in the table
Any help is greatly appreciated as I am pretty stumpped here
I don't know why, but trucks seem to require higher IAC values than cars. IAC values in park with air off should be around 50-60 counts.
Good luck,
Richard
Before the motor dies, the IAC opens up more, but it is like it is never enough to keep the engine running. I have tried increasing the Airflow Decay in Drive table because this seems to fix the problems of this sort in LS1 motors, but it did nothing on my truck.
Is there a way to increase the IAC value when coming down from first gear to keep the engine from dying?
Thanks Richard
Ryan
It does not do this behavior from a second gear stop because the IAC seems to hang at a high number for a much longer time rather than falling (like a first gear stop) and then maxing out in the open position to try and save the motor from a stall condition.
if it does not have one, you need to have a bypass across the intercooler when not in boost, (most likely a large race style) otherwise you will get pressure waves bouncing around, and cause drivability problemd, like the ones you are having.
please post some info on the TB/MAF placement, and bypass/blowoff valves on your setup, and i'll try to help.
Thanks
Ryan.
The throttle body is on the intake side of the blower and the MAF is right before the throttle body. It is a draw through system. The blow off is on the SC itself. It is on the pressure side of the SC and blows off inside the SC case to the non pressure side of inside the supercharger casing. Kind of a wierd setup I know, but twin screws are like this.
I am pretty sure it is a tunning issue. I just somehow need to give it more air in a first gear stop. Either there is someway to tune for that in Edit or if not I should drill the throttle body..?
What do you mean by adding some additional rpms to turn the Whipple? I know you are on a 427ci now, but what does the Radix tune have a car idle at?
Have you tried adjusting the throttle blade screw? Your IAC's in park are right on for a truck engine, but the intercooler is acting like a big plenum and the IAC system can't adjust to the vacuum swings quickly enough. You might try opening the throttle blade to bring the IAC's down to 25 or 30 counts. That'll give the IAC more range of adjustment. WARNING: don't let the throttle blade tip past 0% or you might leave the idle trim cell.
Good luck,
Richard
I really would like to stay at a low idle speed. I know I am starting to get beyond this point, but I need decent fuel milage. When I am sitting in traffic, I don't like to be revving really high and using lots of fuel. (for emissions testing that would also be a dead giveaway...although I could retune for testing day i guess)
Next, I would try raising the timing 2-3º between 400-1200 rpm. Do this in the "High Octane Spark Table".
Your idle speed should be fine with that cam. My wife's truck idles nicely at 650rpm with a Comp Cams 214º on 112ºlsa. I don't think there's any need to raise the idle speed.
Keep us posted on your progress Ryan.
Richard
HERE is what did work: Inside LS1edit v1.3...again, version 1.3 there is a new table under Engine Cal.>Idle+Limiters called "Throttle Cracker" The values at a stop are zeroed out. Well I increased the first two rows and colums (upper left four boxes) to a value of 2.00 and things work great now!!! I guess this will kind of be my "crutch" until the new cam with 117.5lsa goes in.
I hope this can help anyone else with this problem. And thanks to you guys for your input also.
Ryan
Ryan
Richard
