Tuning with Granatelli???
The old ones used to lean out the car
a fair bit. Those helped the '98-'99,
maybe but hurt the '00-'02s. You want
to have a good understanding of which
one you're buying, or you want some
more time spent with Edit.
It's not the diameter, it's how they
jack with the electronics that makes
tuning necessary.
With only headers on that car you should
have negligible HP loss in the stock MAF.
The stock MAFs are pretty cheap. How did
you know the MAF is actually bad, anyway?
Now for the maf code try cleaning the small sensors in the maf. You will find three of them. Use a spray carb cleaner; make sure you get both sides of the sensor. Easiest way is to remove the maf ends. Let them dry before putting the maf back on. If you still have the maf screen you might want to try and clean it to.
What about your air filter? When’s the last time you changed it?
Have you check all your fuses? I might be wrong but are there fuse’s that run the maf and the heaters in the o2 sensors?
and probably this means your closed-loop mixture
is having trouble and carrying that trouble over
to WOT.
GMAF airflow improvement is going to give you a
very small potential gain. GMAF mixture effects
may put you better (naturally-over-rich tune) or
send you to pining hell (naturally-lean tune). On
an '00 I'd bet the latter, but until you have your
O2s working right all bets are off.
Header wrap on the collector and all except the
first couple of inches of primaries might keep
enough heat to light up the O2s without hurting
any welds. Like, wrap whatever you can't see.
Otherwise, I think running the O2 heater power
full time (and making the PCM like it) is the way
to fix it. That's harness rewiring. Somebody ought
to make a kit....
Dunno how long O2 sensors' heater elements last
under continuous power, but seems like it's a
thing to try. I figure it would involve giving
the PCM some dummy loads and putting either
IGN or ballasted IGN to the heaters.
O2s run too cool. You can change the O2s and get
temporary relief but it won't last indefinitely.
You have to keep more heat in or supply heat
power, if you want them to work long and happy.
When did this problem start? After header install? If so how many miles after the install? Did you get the headers jet-hot? Or some kinda protestant?
A lot guys run headers with out heater circuit codes, me included… "it's not normal with a header install" you can tell if you have a problem with the heater in the o2 by letting the car cool over night then turning the key to run but don’t start the car, then get under the car and put your hand around one of the o2 sensors that’s getting the code and see if it starts to get hot. Should take less then 2 minuets. I’m not sure how hot they get but it could be very hot. If it’s not heating up check the others. You should find some heating up “if you still have your rear’s check them to. Oh make sure your fuses are good before you do this, also check them after words
If you have autotap do the same thing and watch the o2’s while the car is in run but not running you should see the O2 mv go down slowly as the o2 sensor heats up.
I think wrapping headers is a good idea but if you have a jet-hot coating then it is point less. Wrap can cause rust because water gets trapped in the wrap. It can also over heat the metal and could cause it to crack.
I don't know whether the LS-1 does this or not, but suspect that
it's the same deal, after the O2s are -expected- to be hot the
heater power may be removed for efficiency's sake and heater
element life.
What does the heater code mean? Maybe it means that the PCM
has reapplied heater power because without it the O2s read too
low, and it thinks this is a fault?
I would like to know for sure about this, the heater control
scheme & trouble codes about it.
