Timing Spike @ WOT on Nitrous Oxide
Here's the latest. We took it to the track and were doing some nitrous shakedown passes on a small shot. He made a pass and burned off all but 2 of the straps on the plugs. I look at the log and at about 6K RPM timing jumps from the flat commanded 13* to a solid 29*. First thing I checked was to make sure that there was no modifier table screwing me up. The IAT sensor is tricked to read 73* temp all the time. ECT temp was solid 190-205*. TPS read 100% throughout the entire pass.
There are only 3 tables that show 29* timing in that region of cylinder airmass (0.80 and up). The park and drive idle tables and the max torque table. Only the torque table goes up to 8K RPM. I changed the torque table to 14* and the idle tables to 12* in order to see which one it is. We changed plugs and did a few blasts on the street but it never fluctuated from 13*.
How does this max torque timing table work? Is there a way that I can identify which table is in use while scanning (besides what I already did)?
This is a 99 F-body tuned in Open loop MAF w/ HPTuners. It is a wet direct port shot.
I agree with Rodney on the spike; log raw TPS voltage along with % and see what you get.
I don't think this has anything to do with TPS voltage. It is back and forth between 4.80 and 4.82 the whole time. I wouldnt call that a short by any means.
I would at least try setting the OLFA table to something else in the 95 and 100 KPa rows. Something different from your PE value so you can see which if either it is using.
And try setting the whole 4800 column in your idle spark table to 12 instead of just the higher airmass rows.
And even if that worked, it doesn't fix what is happening but it will be alot safer when it does.
