LTFT's +20 on Bank 2 after Removing Cats.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ok, since I took out my cats. Just after I start the engine (warm), bank 2 LTFT's hits +20 which is real lean. The car runs rough for a few minutes, then the LTFT's slowly drop to - 2 to -5 and then runs fine.
I have not taken the rear O2's out yet. (gotta get the plugs for the bungs.) And they are still plugged in (didn't want the wires to hang). But codes have been removed with EDIT.
Any idea what is causing this? Is it cause they are plugged in?
No codes at all. It didn't start until I removed the Cats. I will swap the O2's and see.
Could it be my AIR? Its still hooked up, but will be blocking the tubes off today.
joel
Originally Posted by binksz06
If it was AIR it would be both sides, assuming it's functioning correctly. AIR was my 1st thought, also.
joel
The AIR is out and it just did it again tonight.
Guess I will swap the O2 sensors. Can I use the rears??
Originally Posted by WicketMike
when your driving it around does it stay fine? or does it jump up to +20 when you let off the gas and cruise?
It only happens when I let the engine cool for a little while. Before closed loop. And only for a few seconds.
