A/F monitor
Old 04-15-2009, 01:36 AM
CarsandWomen's Avatar
Default A/F monitor
Ive been searchin for about an hour and a half now and cant find anything on it so im forced to start a new thread for a simple freakin question. ugh.
of the 4 wires to the upstream o2 sensor, which is the signal wire? I am hooking up a A/F monitor from autometer. and this is buggin the **** outa me.
id like to tap into the wire somewhat closer to the pcm to keep it out of harms way so if anybody has a wiring diagram that would be awsome.
Old 04-15-2009, 04:43 AM
Droptopws6's Avatar
Im confused, you want to hook into the 02 prior to the cat? Your going to monitor the narrow band sensor?
Old 04-15-2009, 01:11 PM
well correct me if im wrong but hooking into the wideband downstream o2 would give a false reading on the gauge because the cat burns off any exccess fuel.
plus my downstreams are in the car but deleted from the pcm. I have no idea how that might effect it all pertaining to what im doing now but id just rather use the ones the pcm is using so i know what its seing.
like say, correct me if im wrong.
Jeff
Old 04-15-2009, 04:03 PM
Frost's Avatar
Well what do you have, a wideband or an A/F gauge?
The A/F gauges are pretty much just a light show...
Old 04-16-2009, 08:46 AM
Old 04-16-2009, 10:39 PM
Droptopws6's Avatar
He means do you have a wideband 02 senor or just an AFR gauge.
Old 04-16-2009, 11:15 PM
2002CAMAROSSLS1T56's Avatar
You have this? http://store.summitracing.com/partde...5&autoview=sku
Not the best but.... the purple wire in the O2 harness is the signal wire.
Old 04-16-2009, 11:20 PM
Frost's Avatar
Well Jeff, you did say:
......the wideband downstream o2 would give a false ..........
Jeff
just trying to figure out what you actually had.
This makes it easy for you: http://speed-eng.com/store/caspers-l...re-p-3703.html
Old 04-20-2009, 04:17 AM
2002CAMAROLS1T56, yes thats the guage, got it as the Cobalt version though.
FROST, sorry bought yhe confusment. my apologies. By looking at it i thought it was wideband. i can tell by looking at the car the previous owner had parts on it he removed before he sold it. After I started the thread I got a part number and etc etc and its a factory replacement, narrow band.
Unfortunately it rained most of the weekend so nothing got done
