Tuning for Transmission Pressure
In regards to your original post; what are you trying accomplish by adjusting the line pressure?
There are several key points:
- the transmission requires internal parts that support zero slippage when adequate line pressure is applied (i.e. suitable clutches, bands, servo pistons, built with suitable clutch clearances...);
- the PCM or the vacuum modulator must ensure that adequate line pressure is applied during critical events (i.e. during shifts, during high load);
- with the 4L60E/4L80E you should minimize the shift times... during shift transitions the releasing component is "slipping down" and the applying component is "slipping up"... by minimizing the shift time you minimize this transition slip (this is what shift kits did before computers came along)... this should also supported by increasing pressure during shifts; on the 4L60E/4L80E the hydraulic circuit that is applying the component for the next gear is also releasing the component for the previous gear (i.e. fluid pressure that applies the 3/4 clutch also releases the 2nd band)... this is not true of the 6L80/6L90 (which use mutually exclusive hydraulic circuits for each component), so trying to minimize shift times on the 6L80/6L90 may cause binding (destroys clutches by forcing them to slip, and breaks hard parts).
slip is bad, this is what primarily kills a transmissions... slips burns the friction material from the clutches/bands, which in turn promotes more slip... slip heats and burns the fluid which causes it to lose its properties which may also promote more slip.
My $0.02.
Sounds like you all ready have your mind made up and the coarse you want to take. Now that you have efilive, change all the **** you want.
I dont believe I ever bragged about my rock on trans, I didnt have time to. Me along with alot of other poeple got burned on here because of their shotty business.
My fuddle converter has been doing well actually, I still run it! So, you dont know WTF you are talking about. Anything else you want to point out?
Your good on finding old threads, search FLT and dig some up, there reputation speaks for itself.
You can try to lower the shift point, or raise the rev limiter (or maybe both) to widen the gap so the trans has a little more time to shift..
Or, you can see if lowering the shift times (to make it shift faster) helps and/or see if raiseing the pressure helps.
that's why i want a 6 speed or i'm going vaccum modulated.
Changing PCM's wont solve a thing and going vaccum mod doesnt mean that it help your rev limite problem. You need to open up the window to give it more time to shift.
Ramairws6 real race cars have three pedals, put a 6 speed in it and you will be done. Look at the benefits of the six speed better gas mileage.
