Tuning for Transmission Pressure
Or you could increase D0704,6,8 on the rows that are your operating temperature.
If you want to increase pressure all across, then decrease D3801; in this case, use a pressure gauge on the line tap on the side of the case to verify the increase.
Hey Trev, you and speedo should look in the efilive forums, im sure youll find stuff there. Joecar is the man though!
the kind of thing you ought to be asking yourself.
Changing stuff across the board like that doesn't
seem like a thought-out strategy to me.
Ive pumped 60-70 bottles of spray and ~60-80 passes down the 1/4 over the last 3 years on my FLT... My bud has done the same with his 402 stroked TA...
Get it done right, call FLT.
Have you tried changing your VSS table/up the rev limiter a little, etc? When adding power or chaning things up, I dont know a car that hasnt needed some tweaking in the trans. Mine bounced off the rev limiter a few times when I first put it in, I just tuned it out.
another question my car keep breaking 3-4 gear the line pressure is tight because of the servo the builder told me but it still went out for the 5th time if i use modulated would this atleast help?
