LS1 edit vs. Predator...
-Sly
BTW, I have a cam only car, and run plenty of nitrous..my car is tuned with Predator, I need to have the idle in P/N A/C off tweaked, but all else is just fine.
What was done, lets see, the basic rear O2's off, C.O.T. off, adjust TM, Adjusted Misfire Parameters, Idle, scaled for larger injectors, dialed in AFR for idle/cruise&Part throttle, and WOT, raised line pressure, reduced shift time in the tune itself so I dont need to mess with adjusting it, fan turn on/off temp, shift at rpm, and shift at speed settings,reduced timing to 26*max for nitrous use, deleted A.I.R. codes and E.G.R. codes, adjust throttle follower to decrease the surging from a cam, as well added timing under 1200rpms....and the list goes on, so what is it exactly that edit can do that Predator cannot, other than tune yourself once you also buy a laptop?
*EDIT* Forgot, copied the high octane tabel to the low octane minus 1* as well as changed the decay rate for recovery from seeing KR to full timing.
Charlie.
Thanx for all the info!
-Sly
Personally I tuned 2 cars that had Preditor tunes.The owners were sick of getting tunes that did not work.For people that are not real picky,Preditor will work good.But for me I like changing tunes on road trips,with no waiting for a new tune to be sent to me.My current setup would of taken 2 months to get done with Preditor since I downloaded 15 Edit files to get it to run perfect.
, are there any requirements as far as the laptop is concerned for edit?-Sly
