FYI: Close gap on TR6, ran lean
TR6's gapped 35
well, I gapped them to 28, and I went to running rich at idle and LEAN LEAN LEAN in boost.
Spark blowout is GONE... engine is now running like it should just LEAN.. one or two VE adjustments later and its running better than ever.
Just thought I'd drop this out incase someone was having SPARK BLOWOUT issues...
wideband measured lambda (which is defined to be the remaining oxygen proportion).
the less complete the burn. You have basically a fixed coil
current, gap is voltage hence spark power in the hole. "As
much gap as doesn't blow out" (or failure to jump the gap
at max cylinder pressure) is the best you can do and it goes
downhill from there.
Played any with increasing dwell (volt-seconds, equals
current)?
