Couple of codes bothering me
1. p0102 - MAF or VAFA curcuit low input
2. p0141 - o2 sensor heater Curcuit Malfunction Bank 1 sensor 2
3. p0155 - o2 sensor heater Curcuit Malfunction Bank 2 sensor 1
4. p0161 - o2 sensor heater Curcuit Malfunction Bank 2 sensor 2
5. didnt right down number but it was another o2 bank 1 sensor 1
Now I only have 2 o2 sensors. They are the ones on the my Long tube's. I dont have the others bc i have an ORY. Is it fine to run with just the front o2's or should i do something to get the rest? I can get these fixed no problem and i know if the o2's are bad that it would cause my car to run like **** so i figured that would be part of the problem for my car to be running so slow.
The real problem i am having is the first code. The MAF or VAFA code. I tried using 2 other mass air flow's but nothing changed. I even unplugged it while the car was running to see if it changed how it idle'd. Nothing changed. How do i fix this first code. I have no intake mods except for my lid and EGR delete. I even have a paper filter. Its not de-screened or anything. It's untouched. Is there something i am missing or what? What do i need to do to get my car running the way it should.
Any advice would be awesome!
Frost is right. The big red flag is your MAF.
If you disconnected the MAF recently, also check to see if one of your male end pins didnt bend when reconnecting.
