PCM Pegged out (MAF)...
i guess you could grab an aluminum maf bung and weld on a 5" pipe. but you will loose alot of resolution, squeezing the same amount of data on the same table.
but over 700whp just go custom os 2 or 3 bar.
people that have to retune with sd tunes all the time usually forget to tune the Flow rate vs IAT multiplyer table to compensate for air density vs temp.
-carl
