PO327 Knock Sensor Bank 1 - Which one is bank 1?
I had 2 of the same codes stored in my car. Both were PO327: Knock Sensor 1 Circuit Low Imput Bank 1 or 1 Sensor. So this means what?
How can I have 2 of the same codes? Does that mean both sensors are shot? How can I tell which one is bank 1? I can get both sensors for $30 bucks at the dealer, but I just don't feel like tearing the intake off.
Thanks!
Thanks!
Originally Posted by Kurt D
I think that's the code mine threw. I think bank one is the front one. I say this because on mine the front one was a rust ball. Anyway you might as well replace both, I wouldn't want to do it twice.
Bank 1 is always the head that has piston 1
S1 is always the O2 before the Cat, thus is the upstream one and
S2 is always the O2 after the Cat, i.e, downstream
So a HO2B1S1 would be on the LS1, left head, O2 before the cat
Originally Posted by DMNSPD
That's what i'll end up doing. How long did it take you guys to do the change? Is there anything I should be aware of before starting out?
http://www.ls1howto.com/index.php?article=5
Originally Posted by J&JsTA
There is a sensor at the back of the intake that you need to be careful with as it is easily broken if not handled with care when removing the intake
