VE tuning on a '99 C5
I've got a '99 C5 that I've done heads, cam, supporting mods, etc. I've done basic stuff up to this point (Hp Tuners, btw) and it's getting to the point that I need to tackle the VE tables. My understanding is that you put the pcm in SD mode by essentially failing the MAF. Doesn't the '99 revert to the secondary, coarse resolution VE table when you do this? My question is this: how do I put this pcm in SD mode and still use the main VE table?
Thanks in advance.
Scott
Thanks in advance.
Scott
Does that use any of my credits to do? And if I do the custom operating system, what will it take to bring it back to MAF operation after the VE table is dialed, a reload of the original operating system? Sorry if these are noob questions, but I'm learning!![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Scott
Scott
Does the 1 bar enhanced still allow maf operation? Also, is there anyway to get real time tuning as well? I see it's available in the 2bar enhanced, but since I'm NA, I didn't think 2bar would be a wise choice, unless you can run the 2bar as 1bar?
Scott
Scott
So does that mean that I don't have to jump through all the hoops of putting it in sd mode (fail the maf, etc) that would otherwise need to be done if the enhanced os is installed? In other words, just install the enhanced os and bam, it's in sd with no other work on my part? And what about the RTT with the one bar sd enhanced. On my hptuners, only the 2 bar and maf enhanced show rtt being available. RTT would be really handy on the 1 bar enhanced.
BTW, thanks for all your help. It's really appreciated.![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Scott
Scott
Scott,
What I have found in my 2000 Camaro, is that if I run the 2000 OS, I do not need to fail the MAF...if it's unplugged, I can actually leave the codes for the MAF set to "no error reported", and just leave the MAF unplugged, and the 1 bar enhanced os runs fine with no codes set. VE tuning works flawlessly like this too. I have not tried doing the same thing with the stock OS...only the 1-bar enhanced 2000 OS...but now I kinda want to try.
I've also updated my car to a 2002 OS for another reason, and in the 2002 OS, I DO need to fail the MAF in order for SD mode to work properly...if the codes are set to "no error reported" on the 2002 OS (both GM and 1 bar enhanced), the car won't run.
I hope that helps to answer some of your question.
Scott,
Scott
