EFILive question...
Old Dec 24, 2003 | 10:28 AM
hugger427's Avatar
Question EFILive question...
I just bought EFILive v. 5.x and immediately upgraded to 6.2.. however, when connecting to my 1999 SS, XP OS does not see my car on the com port. Thus, I get the "SAE J1850 VPW protocol not detected" error message. To me this sounds like bad cables or maybe it's ODB II interface.
BTW, the engine is actually a C5-R (blocked) 427 but a local shop, that sold me this copy EFIlive, has had his copy of EFIlive working on my car Also, I deinstalled 6.2 and re-installed 5.x and had the same problem...sooooo, I de-installed everything and re-installed 6.2.
Thoughts???
Old Dec 24, 2003 | 10:54 AM
Camaroholic's Avatar
If you download and install this on your laptop:
http://www.ttspowersystems.com/downl...ltest-full.zip
Fire up that software, and select the appropriate COM port.
Then, remove the serial cable half of the AutoTap/EFILive cable from the little black interface box. Short pins 2 & 3 together (with a paperclip, small screwdriver, etc) and run ALDLTest. That checks to see if the serial port on the laptop is accessible / working OK. If it fails, then you should probably investigate whether or not you have an infrared device enabled, a modem conflict, mouse driver / Palm Hotsync / GPS software interference, etc.
If the software passes, well, then it's not the serial port...
-Andrew
Old Dec 24, 2003 | 12:45 PM
jimmyblue's Avatar
Moderator
The EFILive web site also has autotap cable diagnostic
program for download. When you downloaded your
update from 5 to 6, you also need a new serial number
(that matches the cable); not the same as the V5 key.
When I installed software without the cable plugged
into the PC and the car (ign on), it gave me similar
looking grief (been long enough that I can't recall
specifics, just that I ended up doing the install again
sitting in the driver's seat and it was then able to do
its autodetect thing and worked).
Old Dec 24, 2003 | 10:39 PM
parish8's Avatar
single digit dreamer
is the 6.x worth upgrading to? i just got efilive also and it came with the 5.x.
Old Dec 25, 2003 | 08:38 AM
hugger427's Avatar
based on what I've read 6.0 has more funtionality and it's free...however, i'm still trying to get it to hook up to my car. i'm sure it's a setting issue on my PC.
