Impact of Exhaust Flow on Tune
Old Feb 19, 2010 | 07:33 AM
danbrazda's Avatar
Default Impact of Exhaust Flow on Tune
Running 3" Long Tubes into off road straight pipes then FloPro muffler, sometimes cutout before muffler (HiFlo Cats go on once a year for inspection). If I had it tuned with Cats is it worth re-tuning with the straight pipes if that's the way I normally run it or would that be a waste of time?
Old Feb 19, 2010 | 07:39 AM
Dskeet6's Avatar
you should be fine... where was the wideband placed when they tuned it???? cats should only change AF .1-.2 AFR....
Old Feb 19, 2010 | 07:45 AM
danbrazda's Avatar
It wasn't a full tune. Just some tweaking at WOT.
Old Feb 19, 2010 | 08:15 AM
AFASTYZFR1's Avatar
Just have the car re-tuned completely Dan
Everything but wide open throttle is hacked
Old Feb 19, 2010 | 08:53 AM
Dskeet6's Avatar
If this is just a bolt on car..... U are fine. As long as you cruise at stoich and get good gas mileage.... I don't see why he would need a complete tune. Waste of money. Imo
Old Feb 19, 2010 | 08:58 AM
danbrazda's Avatar
It is just a bolt-on car but there were definitely some whacked settings in the previous tune. Time to check in with Frost again.
Old Feb 19, 2010 | 09:12 AM
AFASTYZFR1's Avatar
I'm sure most of your part throttle fueling is off with your hacked tune. Now, that doesn't mean YOU will know/feel difference but Steve and I can.
Old Feb 19, 2010 | 10:26 AM
Dskeet6's Avatar
So someone hacked up the maf table???
Old Feb 19, 2010 | 11:01 AM
Frost's Avatar
No, the IFR. They didn't touch the MAF at all...
Old Feb 19, 2010 | 02:20 PM
danbrazda's Avatar
Sent you an email Steve.
Old Feb 19, 2010 | 04:18 PM
ND2RACE's Avatar
There seems to be some hidden info in here, but I just want to point out that when the exhaust is free'd up (better flow) this will allow the engine to get more air in it. Depending if the car is tuned with a MAF or not will determine how far off the tune will get. If it has a MAF it will compensate for almost all of the change. If it is tuned in speed density it will change a lot and possibly go bad lean depending on the severity of change.
Just thought I'd throw that out there, carry on.
Old Feb 19, 2010 | 06:10 PM
danbrazda's Avatar
Thanks ND2RACE. Yeah there is some background here. Some dispute as to whether or not the previous owner misled me. Bottom line- I don't care about what may or may not have been done to the car in the past. I quite simply want someone who knows what they are doing to tune it, sign off on it and then I'll move on to enjoy the car until I have the bucks to do more.
BTW- I more than likely could just walk away from all discussions and continue driving it to death as I am now (there are no drivability issues immediately apparent), but I like knowing my baseline so I can progress from there.
Old Feb 19, 2010 | 07:45 PM
Dskeet6's Avatar
Oh wow. Does he have aftermarket injectors,???
Yea dude get a new tune
Old Feb 19, 2010 | 08:18 PM
danbrazda's Avatar
"Yea dude get a new tune"
I'm trying to...
Old Feb 20, 2010 | 10:23 AM
RevGTO's Avatar
Pontiacerator
Apart from the background issues, taking off or installing hi-flow cats is not going to make a huge difference. Fuel trimming will compensate for whatever small change in airflow there may be.
Old Feb 20, 2010 | 02:08 PM
Dskeet6's Avatar
I'm trying to...
No excuses.
Old Feb 20, 2010 | 04:32 PM
danbrazda's Avatar
Originally Posted by Dskeet6
No excuses.
Your right but I'm getting mixed signals as to whether or not I will really benefit from a full tune. I'll likely just drop the coin anyway for piece of mind.
Old Feb 21, 2010 | 10:37 PM
Dskeet6's Avatar
Haha I'm just messin with you. Yea it's up to you... I really don't know how messed up ur current tune is now. So you have stock inj and someone messed with the ifr???
Old Feb 22, 2010 | 06:57 AM
danbrazda's Avatar
Lots of mysteries so a fresh tune will be worth it. Should be happening today/tomorrow.
Old Feb 22, 2010 | 08:24 AM
AFASTYZFR1's Avatar
A fresh tune would be a good idea, if you want it right
Now end this thread
